250hp zetect turbo
250hp zetect turbo
I have built a 2.0 zetec turbo and put it in my mk4 1.3 bonus, what would I need to make around 250hp? It has a decomp plate, fiesta rs turbo inlet manifold and ofac ecu, escort rs turbo exhaust manifold and t3 turbo, thanks lee
Bodger of Blackburn
i don't think you'll make it on a standard t3 from an rst, could be done on a cossie t3 though.
will need remapping and what injectors are you using?
i'm assuming the pistons are standard with using a decomp plate and as such i wouldn't want to push much through it.
but 15psi would probably get you there or very close, just get a bigger housing fitted e.g. 0.48 exhaust.
Ok well ill pick up a cossy t3 then, at the moment I'm usind the standerd fiesta rs turbo injectors, what injectors would I need? And I didn't think the fiesta rs turbo ecu could be re mapped only a chip put in? Or am I wrong? Yeah I'm using standerd pistons for now
if it were me i would bin the turbo the injectors and the management
fit some up-rated valve springs
ms2
vxr injectors
cossie t3
and run it 1bar boost max and see what it
does
ms2
vxr injectors
cossie t3
does
JK12
33
26-04-2021 12:09 PM
