Help needed asap plz!
Old 04-03-2011, 07:05 PM
jodyhoare
jodyhoare's Avatar
Default Help needed asap plz!
Hi guys, i have finally put my engine in after a full rebuild, starts lovely with a flick of the key and runs great! but this is besides the point!!
i thought id change the clutch ratchet while i was at it, got the pedal box out and put the ratchet on no problem.... however i forgot how the Pawl went back on and cannot for the life of me seem to get it right!! its really bugging me as thats all that holding me back, i just cant seem to get the right direction of the pawl and spring right, does anyone have any pictures i could use as a referance please??
i will be extreemly greatful!!!
thanks guys
Old 05-03-2011, 04:56 PM
studabear
studabear's Avatar
Is it not in a haynes manual?
Old 06-03-2011, 07:52 AM
jodyhoare
jodyhoare's Avatar
i checked my Haynes PDF and the only section relating to clutch/gears is section 7 which has no mention of clutch pedal,pawl or ratchet removal. and for some reason im missing chapters 6,7,8 in my PDF!! lol
if anyone could supply justy a picture of a pedal box removed with the pawl still attached so i could use it as a referance i would be extreemly greatful!!!
im hoping to get it sorted tomorrow
Old 06-03-2011, 04:49 PM
jodyhoare
jodyhoare's Avatar
anyone plz?
Old 06-03-2011, 04:54 PM
Cossy Mike
Cossy Mike's Avatar
It's spring loaded, cable runs through the middle of the ratchet and you'll have to put a block of wood under the pedal to hold it up.
Then pull the Black pawl back and pull the cable/ratchet through it, then let go.
When your done remove block and it will all tighen up, then press pedal a couple of times and you'll hear a couple more clicks when it gets tight.
It's fiddly but you'll manage
Old 06-03-2011, 05:10 PM
jodyhoare
jodyhoare's Avatar
thanks for the reply, but im familliar with that part, the problem im having is that i have removed the pawl with its small spring from the pedal, and cant seem to figure how it goes back in.... its really frustrating me as this is all i need to do before im mdriving it again
Old 06-03-2011, 05:13 PM
Cossy Mike
Cossy Mike's Avatar
Ahh sorry, I know what you mean the small Black toothed thing. I remember leaving it on mine as it would'nt budge and I did'nt want to break it
hope you get sorted!
JoeyBoyden
04-01-2024 02:36 PM
Johnsie
Ford Focus ST
08-09-2015 02:39 PM
col93saphcos
07-08-2015 03:21 PM
Quick Reply: Help needed asap plz!
