MFI to EFI sandwich plate any good?
24-02-2011, 10:28 PM
I want my car converting to EFI and have been told if i keep my MFI head i would need a sandwich plate to make the EFI injectors work,but is there a downside to this?Would i be better off in long run sourcing a EFI head?Cheers.
24-02-2011, 10:34 PM
Formerly know as Puss
I run one no problems and a few on here do to
24-02-2011, 10:37 PM
im usin one and have no probs aswell
24-02-2011, 10:41 PM
Ok lads, i thought it was often used,someone said today that they obstruted the injectors in some way that may cause problems,hence why im asking.
24-02-2011, 11:04 PM
Was running with efi fuel rail with greens
25-02-2011, 07:23 AM
Balls Deep!
25-02-2011, 07:55 AM
Bodger of Blackburn
I was running one without problems.
You could grind out the ports a little like in the efi heads, only seen it being done once.
Would be a head off job though.
25-02-2011, 09:11 PM
'got one as well, only downside is that there isnt enough room left to fit a strutbrace, so Im told.
25-02-2011, 09:23 PM
It can be fitted as i had one on mine you have to squash it were it goes behind the inlet
25-02-2011, 09:33 PM
Bodger of Blackburn
Quote:
Originally Posted by
ArjanRS80
welder at the ready lol!
that's what i did, chopped the ends off the mounting bracket parts and rewelded.
26-02-2011, 11:59 AM
xr2wishy
sounds like a plan..gonna give it a try cheers
27-02-2011, 11:40 AM
Ask me a question!
An EFi conversion plate has benifits and no downsides.
27-02-2011, 01:24 PM
unless its a badly made one of course!
27-02-2011, 03:43 PM
my adapter plate is like a work of art.
27-02-2011, 08:56 PM
where did you get that from dude
cheers
02-03-2011, 10:23 AM
Ask me a question!
stu no offence mate it dont look that great from here?
Does the injector section have a tappered cut as it looks like its just milled out flat.
If it is like this the fuel will not flow nicely and is not a great work of art like you said. lol.
02-03-2011, 06:33 PM
Its from ferriday, was about £110
Jano, it is tapered, the picture doesn't show it very well
markk
02-12-2021 06:59 PM
EoinXR3
07-09-2015 05:44 AM
Dahl88
22-08-2015 08:16 PM
marky_g
17-08-2015 12:21 PM
marky_g
15-08-2015 10:43 AM
