Whos done the IB5 swap?
Old 20-02-2011, 09:19 PM
Rob_DOHC
Rob_DOHC's Avatar
Default Whos done the IB5 swap?
Think i've just about finished fitting the ib5, its a front starter and now has my bc lsd fitted.
BUT i've had to really mess around with the release bearing, any one got any part numbers?
Also
I need a clutch arm bush as it didn't come with one, my bc bush didn't fit, might a late bc bush fit? as i can't find one specific to the ib5
Rob,
Old 20-02-2011, 10:06 PM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
what size is the shaft 35mm?
Old 20-02-2011, 10:10 PM
Rob_DOHC
Rob_DOHC's Avatar
Sorry Jano, which shaft?
Rob,
Old 20-02-2011, 10:11 PM
Rob_DOHC
Rob_DOHC's Avatar
On the clutch arm? 16mm
Old 20-02-2011, 10:23 PM
Versus_Creations
Ask me a question!
main shaft.
You need a bearing to fit yes?
If so is it a 35mm you need?
Old 21-02-2011, 10:28 AM
Rob_DOHC
Rob_DOHC's Avatar
ahhh i see, sorry. Im not sure but will have a measure. Do you have them?
Old 21-02-2011, 11:31 AM
Karlos G
Balls Deep!
Karlos G's Avatar
I bought my release bearing from Ford as the one that came with my AP Clutch was too small, just said I needed the later larger one and he knew exactly what I ment.
Old 21-02-2011, 11:35 AM
Rob_DOHC
Rob_DOHC's Avatar
thats what i thought karlos, so i bought the later larger one and its still too small
My gearbox came with a sticker that said, must fit over sized release bearing... finis number **** So i bought that and it was the same as the larger ib5 bearing
Its all good fun i guess.
Old 21-02-2011, 11:49 AM
Karlos G
Balls Deep!
Karlos G's Avatar
hmm that is odd, there isnt a sleeve left on your input shaft or something from an old bearing maybe?
Old 21-02-2011, 12:49 PM
RUBY123
RUBY123's Avatar
a bit off topic but when you fit the ib5 box do you use the standard clutch kit and just swap the release bearing or do you have to swap pressure plate as well
Old 21-02-2011, 01:07 PM
Rob_DOHC
Rob_DOHC's Avatar
Unfortunately not i've already removed it. I got so pissed off in the end i ground down the case and pressed on a new smaller sleeve which means i can use the release bearing i bought, HOWEVER i can see it casing problems so just wanted future options.
Now i just need a clutch arm bush as the new box doesn't have one
also! how difficult should the clutch arm be to fully depress by hand? mine seems amazingly stiff, this may just be because of the arm bush..... just trying to work out if there is something that could stop the clutch being released?
Rob,
Old 21-02-2011, 01:08 PM
Rob_DOHC
Rob_DOHC's Avatar
I am using an rst clutch kit, the only thing you have change clutch wise is the release bearing.
Rob
Old 21-02-2011, 02:09 PM
Karlos G
Balls Deep!
Karlos G's Avatar
If it's fitted to the car then very very stiff depending what clutch you fitted, I cant move mine by hand really (AP CP2000-35).
Old 21-02-2011, 02:11 PM
Rob_DOHC
Rob_DOHC's Avatar
Ok thats reassuring cheers mate, just had a panic moment thinking more stuff might be about to go wrong! Its the helix equivalent of the ap.
Rob,
Old 21-02-2011, 05:47 PM
orionmojo
orionmojo's Avatar
Rob,
i have that setup on the iB5. Lsd fitted to mine too.
you need the changeover year release bearing, the Zetec one slips the clutch like fuck (trust me ) and cvh one doesn't fit at all which you've already found out.
Old 21-02-2011, 06:47 PM
Rob_DOHC
Rob_DOHC's Avatar
Oh cock. Any ideas on part number? the one i have is from an escort rs2k which was supposed to be the correct one, its the same height as the cvh one so shouldn't (touch wood) slip due to the clutch not fully engaging.
At the time i did go into ford and ask for a change over year bearing but the guy just looked at me blankly.
Rob,
Old 22-02-2011, 05:01 PM
orionmojo
orionmojo's Avatar
i'm sorry mate i dont have any idea of the part number. i had my uncle fit it for me at his garage, as i couldn't be arsed having the b0ox off twice in a week!
sorry i can't be more help
Old 22-02-2011, 05:24 PM
gaz s1
gaz s1's Avatar
ive just changed the clutch on my runabout escort si and had a right nightmare getting the right release bearing, its a fucking minefield!!
Old 22-02-2011, 05:44 PM
jaiscossie
jaiscossie's Avatar
The bearing you need should be part number 6164967 i think mate, its a mk5b one.
You also need the speedo drive (red one) and the breather pipe.
Old 22-02-2011, 05:48 PM
jaiscossie
jaiscossie's Avatar
When you put that part number into google it comes up with this one? Was told this is deffo the one you need but not tried it yet, can anyone else confirm? It states cosworth but apparently fits all older type transits to
http://www.part-box.com/ford-escort-...g-p-31885.html
Also worth reading here, especially 14th post down
https://passionford.com/forum/ford-e...el-escort.html
Old 22-02-2011, 06:37 PM
Rob_DOHC
Rob_DOHC's Avatar
My box came with a sticker saying MUST USE FINIS NUMBER 6847097. This wasn't correct for my box, it was from an rs2000 4x4 (i think).
What breather do i need to get?
And Jaiscossie that is not the correct bearing, it it will not work with the rst clutch arm AFAIK,
Rob,
Old 22-02-2011, 06:38 PM
Rob_DOHC
Rob_DOHC's Avatar
Hiya mate,
What year is your car and do you know the part number of the bearing you got in the end?
Might help us out a lot!
Rob,
Old 22-02-2011, 06:42 PM
jaiscossie
jaiscossie's Avatar
Rob what car did your ib5 come off of?
Old 22-02-2011, 06:50 PM
Rob_DOHC
Rob_DOHC's Avatar
I THINK, a mk5 diesel van. It has front bottom mount starter. So far.. i think its probably this one http://cgi.ebay.co.uk/escort-van-car...item25616d55cd
Not sure on ratios and mine was a recon unit. If you look in the second picture you can see the style of release bearing you need.
Rob,
Old 22-02-2011, 06:54 PM
Rob_DOHC
Rob_DOHC's Avatar
http://cgi.ebay.co.uk/FORD-ESCORT-1-...item2a0e644105
http://cgi.ebay.co.uk/FORD-ESCORT-1-...item2a0e644108
This was who i bought it off, i can't remember which one i bought though mk5 or mk6, not sure what the differences would be... probably release bearing lol.
Old 22-02-2011, 07:01 PM
jaiscossie
jaiscossie's Avatar
Thats the same guy who i got mine off mate.What are you meant to fit where the reverse light switch goes?
Old 22-02-2011, 07:07 PM
Rob_DOHC
Rob_DOHC's Avatar
Mine came with a reverse light switch, different to an RST, the only thing to do IMO is to get a reverse light switch and connector from fords (or who ever) and wire it into your car. You won't be able to put your rst switch onto the IB5
I've got the speedo drive, but you can just use your RST one as its the same. Every thing SEEMS to work minus the reverse light switch and the release bearing.....
Rob,
Old 22-02-2011, 07:11 PM
jaiscossie
jaiscossie's Avatar
Going to go and have a look in the garage now and see if mine came with a reverse light switch lol
Old 22-02-2011, 07:13 PM
jaiscossie
jaiscossie's Avatar
In another post i found this below.
you'll need the changeover year release bearing, as both the CVH or ZETEC wont fit.
I have had to buy a larger (but flat) release bearing from a 95-00 escort diesel to fit over the input shaft of the gearbox
The release bearing on the Ib5 box is different did you change it?
theres a crossover year circa 95 / 96 i think.
Old 22-02-2011, 07:16 PM
Rob_DOHC
Rob_DOHC's Avatar
Yea thats what i keep hearing! but i went into fords and they just looked at me like a was a bellend when i asked for a MK5b / change over year bearing. If any one has the part number it would be really handy!
Old 22-02-2011, 07:24 PM
jaiscossie
jaiscossie's Avatar
Do you know what is stamped on the case of the gearbox? if its say 96wt then its from a 96 car.
Old 22-02-2011, 07:25 PM
jaiscossie
jaiscossie's Avatar
I was told the number i gave you above is the mk5b release bearing number?
Rob_DOHC
Rob_DOHC's Avatar
I will have a look in day light mate, it still has a tag on it.
Rob,
Old 22-02-2011, 07:28 PM
Rob_DOHC
Rob_DOHC's Avatar
I got given a different part number which was still wrong. However that deffo isn't the type you need unless you have a different style of clutch fork.
This is the type you need
With the wings for the fork to hook into.
Rob,
Old 22-02-2011, 07:39 PM
jaiscossie
jaiscossie's Avatar
Ok right now i see, im searching now to see what i can find
Old 22-02-2011, 09:12 PM
jaiscossie
jaiscossie's Avatar
With the one you pictured above what is wrong with it? is the centre bore to small to go on the spline?
Old 22-02-2011, 09:15 PM
jaiscossie
jaiscossie's Avatar
If you look at this one for example it says it fits rs turbo and 1.8 diesel mk5 ?
http://cgi.ebay.co.uk/CLUTCH-RELEASE...ht_1808wt_1139
Old 22-02-2011, 09:26 PM
phil_rs
yam yammer
phil_rs's Avatar
Drop 10th_racer a PM bud, he has the part number written down from when he fitted his IB5.
On another note, I still need to have a look for a fuel sender loom for ya
Old 22-02-2011, 09:28 PM
Rob_DOHC
Rob_DOHC's Avatar
Yes but that will probably be with a bc box. The ib5 diesel's have a larged dia release bearing. My rst one will not fit.
For now i have ground the shaft slightly smaller and pressed on a new cage part and have fitted the bearing from the rs2000. BUT its not totally free moving and im not sure if its the correct height (ie my clutch might not fully engage).
I knew i should have just fitted an mtx75. lol
Rob,
Old 22-02-2011, 09:29 PM
Rob_DOHC
Rob_DOHC's Avatar
Haha, cheers mate... drop me a PM if you do have it buddy.
Actually 10th racer kindly gave me the part number for the bearing i have 'made' fit. Just wondering if he has a slightly different box....
Rob,
Quick Reply: Whos done the IB5 swap?
