How to setup co2 without a gas analyser!
C16OSY
Need some help! I think my car has flooded! Just wondering if anyone knows of an easy way to setup the CO2 at home without a gas analyser! I know my CO2 is out because i had to adjust it when my dump valve was leaking air! Any help would be much appreciated.
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Take of the airbox to expose the padle. Warm the engine up and only make adjustments when the fan is off. Now gently push down on the padle, You will only need to move it 1mm max. Push farther and the engine will stall. Do the engine revs increase or decrease. If they increase then its lean, If they decrease then its rich. When turning the mixture screw clockwise richens it and anticlockwise leans it out. You will get to a point where the revs dont rise or fall, When you reach this point make it slightly rich. And I mean slightly. You might have to push down on the mixture screw to engage it, It depends on what type you have. One last thing the head of the mixture screw is a 3mm allen key and you will need a LONG reach allen key to reach it. And thats pretty much it my friends. Have fun.
This applies to both S1 and S2, Also after each time you make an adjustment cover the mixture screw hole so your not drawing in air. If going for an MOT make it slightly lean just in case then alter later. Its better than having to pay another £40 if its slightly over.
C16OSY
thanx mate il try that 2moro. just hope the fucking thing starts !!!!!![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
todays was the first time i had it running since fitting a dump valve blanking plug!
i warmed it up till the fans came on, went to take it round the block for a spin, when it decided to cut out! since then it just doesnt want to start!!!!!
SMILER258
28-09-2015 09:04 AM
adjustment, air, analyser, analysis, car, co2, escort, gas, mixture, motorcycle, rapidshare, rs, setting, setup, turbo
