Need a couple of bits
Old 01-03-2011, 12:08 PM
cj_rst
S2 RST
cj_rst's Avatar
Default Need a couple of bits
Does anyone have a spare plate that the ARB mounts on to (passenger side)? My turbo just failed its MOT because the mounting plate is cracked. I'd prefer a new one rather than getting mine welded.
I also need a caliper clip as one of mine has come off! It's for the later style calipers that have bigger holes where the clip fits in to.
Can anyone help? Cheers
Old 01-03-2011, 10:57 PM
escort_matt
escort_matt's Avatar
is it the clip bit at the front that pulls the caliper over?on the out side of the caliper?
Old 01-03-2011, 11:13 PM
muz
Wye Valley Hardcore
muz's Avatar
I have a ARB corner plate you can have but can't get to the post office this week. Can pick it up, but it's a bit of a trek?
Old 01-03-2011, 11:26 PM
Trip down the breakers, pull one off a mk4,quite a few mk4s about in the breakers
Old 02-03-2011, 11:43 AM
cj_rst
S2 RST
cj_rst's Avatar
It's the metal clip that goes on the side of the caliper, ie if you were looking straight through the wheel you'd see the side of the caliper and the clip attached to it.
Old 02-03-2011, 11:44 AM
cj_rst
S2 RST
cj_rst's Avatar
Don't mind waiting, that would be great if you've got one
Old 02-03-2011, 11:45 AM
cj_rst
S2 RST
cj_rst's Avatar
Ok I might have a look at the weekend - I thought only the better mk4 models had the arb tho? Might be difficult to find xr3's or RST's just in a scrappy?
Old 02-03-2011, 08:31 PM
ryan_gwa
ryan_gwa's Avatar
I wont have the ARB plate as I need mine, but I have a pair of RST calipers that I am not using, if you want I can see if mine still have the clips?
Old 02-03-2011, 08:34 PM
ryan_gwa
ryan_gwa's Avatar
This the one?
A picture I found in Google images.
Old 03-03-2011, 11:53 AM
cj_rst
S2 RST
cj_rst's Avatar
yes I think that's the clip. Are those standard RST brakes tho? Look a bit bigger for some reason?
Old 03-03-2011, 12:26 PM
Jimmyc
Jimmyc's Avatar
The base models have front ARB's just not very thick ones, the ARB bushes may therefore be different too so dont chuck your old ones out just in case!
Old 03-03-2011, 01:02 PM
cj_rst
S2 RST
cj_rst's Avatar
Aha! Thanks, didn't know that
charlierothwell
Ford KA
05-11-2015 06:56 PM
3drRich
13-09-2015 07:32 PM
03-09-2015 10:49 AM
Quick Reply: Need a couple of bits
