front splitter
any i suppose if you cut it to size and is reasonably flexible..couple of the lads had one off a seat ibiza which looked nice and subtle and another had one off a laguna with the holes in it...cant remember what bumper they had on though
most the popular splitters will fit when cut down in the middle etc, but they do sit better on a 90 spec instead of the 88 spec, as the 88 spec curves away underneath, whereas the 90 spec stops flat at the bottom making the join neater looking
but yeah, early laguna splitter, early ibiza splitter, iv seen the old skool seat toledo (i think?) style splitter, plus the golf vr6 splitter can be fitted altho iv only seen that on a 90 spec. oh and the centre part of an escort cossie splitter has been done before
not sayin all of the above look good, but iv seen them done
heres mine with the laguna splitter... i found it almost impossible to do untill i saw someone pot rivert theres so i riverted mine on it had silver riverts then i just sprayed over them in back. look close you could see them but they look ok so all good! saw some at shows with same thing... maybe if u make special brackes it would be ok but then it would be loose so rivert it imo
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
