It's the same 12, but with idle rpm (not 1000rpm) and with MAP hose disconnected and plugged.
Yeah should be set as above for a stock engine running stock boost.
Originally Posted by Versus_Creations
There is more to setting the engine up to feel right than ignition timing fella.
12degree is the very least advance you should have. Depending on boost and fueling etc etc.
IMO 12deg is the MOST you should have, most MFI RST's IME end up between 8-10deg of static advance when running reasonable boost (14psi+) on 95RON fuel.
