Best place to fit oil temp sender on rs turbo
Hi guys!!
I want to fit a oil temp gauge on my RS turbo and I need to solve some doubts before buy the gauge:
I would like to know where is the best place to fit an oil temperature sender on RS turbos.....
Also need to know the normal driving and fast driving working oil temperature on Rs turbos...
Is it right for a Rs turbos an Oil temp Gauge with scale 50-120ºc??
Thanks in advance!!
CheeRS.
Thanks in advance!!
CheeRS.
Id like to know the best working oil temps aswell...
Alot of people put the oil sender in the sump, i dont think this i ideal however. Ive seen 1 or 2 installs with the sender in a remote filter plate!
50-120c seems about right, i think you'd see temps aroung 80-110c, but i dont really know!
on my converted 2i i bought a sandwich plate adaptor on ebay and screwed the sender into there.it has 4 outputs so i put my oil pressure one in there too.normally it sits about 70-80 but when i give it a bit then it will go upto about 90ish
Bodger of Blackburn
fittted to the sump will be more accurate and won't be carrying heat soak from the block.
ideally oil needs to be around 85 degrees, but can be fine over 100degrees, some oils vary in stability when they get hotter.
50-120 degree scale is fine for what you'll need.
try fitting an oil cooler with a thermostatic sandwich plate if it gets too hot.
Balls Deep!
If the oil is heatsoaked then that is the temperature it actually is... Which is what you need to know! lol
Oil sitting in the sump will be cooler and not a true reading of how hot/cold it is going round the engine.
Sandwich plate between oil cooler and filter is best IMO.
Temperature wise I've never seen mine go over 98 degree's even when driven really hard, normally sits around 80 degree's with ambient temps of around 20 degree's, in the winter it stays quite a bit cooler.
I use a T piece on the turbo oil feed, but with the standard sensor for the oil light on another T piece, it can get a bit like a tree coming out of your block!
use a sump plug adaptor mate , 60-70 for normal driving and 90 for a bit more toe .
just be carefull when u run the wire up the back of the bulk head , the wire could get tangles around the stearing column !!!OOOPS
Ben
Ben
big_Rad
15-09-2017 09:36 AM
COSWORLD
14-08-2015 07:40 AM
track.focus'd
12-08-2015 05:53 PM
