RS Turbo Metering head.
Hi I have a series one RS turbo and the metering unit has failed, could only find a series two unit, i fitted the unit but im not getting any fuel out.
There is fuel at the cold start but none at injectors, is it a incompatable problem or a sensor problem?
Dont think any fuel is returning in return to tank,could it be the regulator?
Do i need to change anything else to be compatable?
Have tried holding metering flap down, have tried changing the pressure regulator and tried a couple of s2 metering heads.
Could it be the fuel pump on the way out?? as in not enough pressure?
Can any one give me advice or a specialist garage where i can take it, i live in Dudley West Midlands.
Im at my wits end, any one please help.
metering head
Will try what you have said, will try anything, its doing my head in, will post my result but will not be able to work on car until weekend, thanks.
any luck with this yet i have the same problem, fuel pressure into the unit after the filter, fuel pressure at the return outlet and fuel pressure to the cold start valve but nothing going to the injectors have tried another (said to be good) metering unit but its exactly the same the car has been stripped and rebuilt for paintwork and turbo conversion
metering head
Hi...Still not solved my problem, but have been told its low fuel pressure.
There is a gorse type filter (been told) at the exit of the fuel tank, before the pump as this could be part blocked???
The pressure should be 5.5 to 6.0 bar at the metering head.
I will not have time to check mine for a couple of weeks but will let you know how i get on, if you solve your problem please let me know as im close to suicide..ha ha
My mail address is s.byng@sky.com to make things easy.
Regards
Regards
i had similar problem on my old s2 ended up being a load of shit in the tank and fuel lines, i took the lot off cleaned it out ,new filter ran perfect after. hope this helps.
JK12
33
26-04-2021 12:09 PM
