rolling road set up
hi lads just got my s2 back from my local garage its been on rolling road and he said he set it up i got print out and it woz 132 bhp it got a k@n on it and full stainless exhaust should it be more than that just dond seem to have any balls in it this is my first rs
you can not take what the rolling road says to be 100% accurate, they never are!
so long as all the rr prep was done right for monitoring and the engine is running bob on then its a good health check and shows the engine is ok.
If standard boost thats about right mate,in an ideal world it would be nice be little more but all depends on wear on engine as these car are old plus as said no 2 rolling roads are the same.Get boost turned up to 14 psi with chip, 31 actuator and will be 160bhp+ and will feel lot quicker.They are slow as standard.
1 Post
That's not too bad really, mine made 127 @ pts when it was standard bar a bleed valve ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
I got 155 @ powers with a -31 and mongoose, with the boost upped to 10psi, then I got hooked on more power
i'm not saying he was liying just that rolling roads aren't very accurate. brilliant for setting up and doing comparisons to see improvements but won't give you the exact bhp figure.
i've heard good things about them. got a link to the thread?
don't take my comment in a bad way or personally mate theres always debate when it comes to rollers and it might be accurate for one car but not another. going off personal experiance rollers can be way off in some cases but so long as they are consistent one run to the next will be good for seeing improvements and setting up.
Escortdriver1
01-11-2015 07:55 PM
