s2 arb size?
Orions come with a Rear ARB, XR3i's and cab's don't... I thought Orion and RST were the same but, it seems Series 1 turbos use a 12mm from an Orion, and a series 2 turbo uses a 16mm.
I would like a 16mm for my Orion!
Turbocharging Technician
you need four clamps (two close to the body mounts and two very near the ends of the arb) and clamp them up. Clamps will have to be made either by you if your handy or by a machinist. Get four 2" long pieces of 1" square bar, drill two holes in each (same size as the arb) and one central hole for the clamp bolt, then split in half lengthways.
Johnny Knoxville
30-09-2015 07:21 AM
