little bit of help/ advice please
hi peeps, just busy on sorting the wiring for the fuel pump relay and need to know where the deceleration cut off valve is.ive been told its under the throttle body on k jet but unsure about ke. also need to know what fuse in the fuse box is for the relay (30 amp i think). also can anyone tell mewhat fused link wire is? can i use normal wire and still be protected by the fuse in the fuse box? any help much appreciated cheers
