Gearbox ib5 or mtx75 whats best??
Hey guys, as the title says really, which box would be best for my series2. Engines still a cvh so focus Rs Mtx and st170 gear box is a no no due to starter bein at rear,
Hopefully going to be mid 200bhp so want a gearbox that can cope, cheeRS
Turbocharging Technician
Thats quite dear IMO, Ive done one for around Ł150 before
Ł50-gearbox + shafts + speedo drive + clutch cable and gearlinkage
Ł100-clutch
modified mk5 shafts myself
made my own mounts
made my own gearlinkage and all other ancillaries
MTX is def the best bet in terms of reliability, clutch size (240mm instead of a pishy 220mm) and gear ratios are much better in MTX
Ł100-clutch
made my own mounts
PLUS, its being fitted to a mk5 escort
So wouldn't need modified shafts etc, mounts should already be there/available, might have to play around and make a mount up to use the equal length shaft bearing...?
What hubs and shafts are you using at the moment Jimbo?
Rob,
Rob,
Ah, never read that, In that case iys easy! nuts and bolts! Wouldnt even consider the BC box rubbish four speed that had fifth gear retrofitted OUTSIDE the box dodgy diff bearings, crap layshaft bearings, soft small gears
Ł100-clutch
made my own mounts
Ł100-clutch
made my own mounts
and a paddle clutch is around Ł300
That Ł900 before u have started
I thought it was going in a series 2 ?
I'd love to rob, tell you what, next show come see my car and if a mtx will go in I might do it if I'm keepingit
I know it makes sense, but for me I'd like a diff in it, so 600,100 for the box, flywheel and clutch to suit cvh?? It would be the best part of a grand
My hubs and shafts are 1.4 escort ones!
Will do matey, had a quick look around for you at ford fair (hear your a big lad), catch you next time mate.
Btw, forcus RS lsd went on ebay the other night for 295, so well worth keeping a look out!
http://cgi.ebay.co.uk/Ford-Focus-RS-...item2310faef9e
Rob,
Rob,
just a thought would the mtx 75 box out of the cougar/st200/st24 work the starters at the top and main body faces away from the fly, with cable shifting, but hydro clutch and they will take 200bhp and C&G motorsport do an uprated clutch for the st 200 for about Ł160 or is that the same box as focus/st170?
Ive use a 2 litre mandildo one twice, and a frs one once all 240mm not 220mm like the bc/ib5 ones (shirt buttons) People rant and rave about big brakes, but never say much when you say you have a big clutch, both are frictional devices and work on the same principals.
Does 20mm really make that much difference on a 220mm clutch?
The 20mm from 240mm XR3i Brakes to RS Turbo 260mm Brakes makes a fair bit guess and then onto 278/283mm Cossie ones.
Don't need a paddle clutch and massive left leg either i guess lol!
Dont need a paddle clutch for 200bhp (see below) and atb can be had for Ł450, but is not essential.
A std 240mm mondeo clutch will take 200bhp (mine took 214lb ft and 204 bhp no probs, and it was second hand)
Cheapest diff I found was Ł500 with no bearings and that was not including vat? I
I don't think there s any point running an mtx for 200bhp the bc would cope fine IMO
you do the maths on the increase in surface area, dont forget that the friction discs are wider too. The thing with a clutch is that it either holds or doesnt, brakes will always work, but obviously will fade quicker if smaller.
Rough surface area of a 220mm clutch is 267cm^2
Rough surface area of a 240mm clutch is 339cm^2
Rob,
Why bother running an mtx with a standard diff?? No point in changing from the LSD bc box as it would just spin one wheel?
Yes it is. And assuming the centre is 120mm (no idea if it is or not, but the difference will be the same).
PS my maths was wrong, i just used the diameter not the radius lol
Edited now!
For 200 bhp i still think an ib5 is man enough for the job, time will tell with mine anyhow! but if your up for it an mtx75 is the obvious winner.
Rob,
Edited now!
Rob,
thought of the mtx75 for mine ,have used the ib5 box from escort mk5 1.8 zetec just had to swop bolts around on rear of box for s1 mounting . back to s1 bc box now but will prob top out 125 mph and sound like its in 4th at 80mph flat out on motor way lol . 4.27 final drive for ya lol , wonder if any one sells brackets , shafts , and mounts in kit form for the average guy doing diy job at a good price . some one could make a mint !
As above, does anyone do the shafts etc for the MTX75 conversion or recommend anyone who knows what their doing to make the shafts and brackets as a self bolt in job ?
chowfornow
14
05-01-2019 09:01 PM
cossirob
16-09-2015 07:39 PM
