Amal valve on Ofab??
Awritey, I was tinkerin in garage tonight and I'm in middle of convertin my Rs turbo van to Ofab from mfi Noticed there's no plug on Ofab engine loom for the Amal valve,... Do I need an Amal valve on Ofab and if not where do the small hoses from turbo and actuator go to??
CheeRS bondy
CheeRS bondy
either loop the hose from the comp housing to the actuator, or fit a bleed valve (not my cup of tea) or fit some sort of electrical boost controller (i use a hks one)
failling that you could use your amal valve to give you 2 stage boost + to live and - to a switch and then ground.
