Misfire on S2!!!
Misfire on S2!!!
When i get on boost its like the car is holding back and misfiring ok when i let of the gas though, changed the plugs and all the tips were brown/white but dry
Changed the dizzy cap and arm too!!!
Any ideas?????
Any ideas?????
Originally Posted by Hartyboy
boost leaking you mean!!!
After doin headgasket, got myne running and if you put your foot to the floor it badly miss-fired. \but was ok if you let the boost slowly build up.
I tried coil, cap, and leads - had new plugs in from when i did h/gasket. Fault was the plugs though, standard plugs wern't good enough and it was blowing out the spark. Also the gap wasn't right, so got some NGK's and set the gap properly and now all ok!
Better get some new ones
Changed Hoses and removed dump valve but its still doing it!!!
Its like machine gun fire from the exhaust when its on full boost but when i back off its ok doesnt happen so much in 1st and 2nd???
Ex Full Price gold member
does it still do it if you try and gently press the throttle throught the rev range like as it comes on boost if flooring it it was like hitting a brick wall with missing and shit?
anyway i had the same sort of problem and it turned out to be a knackered chip as mine was chipped but it turned out to be fucked chip and a new one stopped all the fugging about
Martin
Martin
hi m8 my mates s2 was doing this when some one played around with the idael screw it had been wound out to mush so there was to much air set it to whot mine was and it was running as good as new
worth trying it m8 try turning it half a turn at a time and she how you get on
have you checked the cam timing ,as on the bottom pulley there is a groove you dont use that ,could be map sensor or fuel pressure related,does your car run hot?
It sounds to me as though the spark is getting blown out! I would get some Champion QC59YC fast road plugs as these are designed to cope with slightly uprated boost and the standard NGK BCR8ES arn't. It is also very important that the plugs are gapped correctly aswell!
Matt
Matt
Also another thing check your HT Leads they may be well worn if they are still the original ones! The ones to go for if you were thinking of changing them would be the Magnecor R-100 10mm leads as these really are the dogs dangalies and come with a life time guarantee!
Matt
Matt
Harty i got exactly the same problem. It only happened since fitting new turbo last week. Does it sound tappety as well? I have been told a few things
1. timing
2. air leak
3. plus
4. cam seal
Let me know if you solve it. The guy who did me engine th eother week (low comp) he is coming tomorrow to have a look so if he solves my prob i will let you know dude
1. timing
2. air leak
3. plus
4. cam seal
me and 1 of my mates have just had the exact same problem both got brand new ngk copper core plugs boost comes in sounds like a tank hence throw them away and ring motorsport developments for a good set of motorcraft ones i think they are only 15 quid a set
