is my turbo fooked
is my turbo fooked
hi chaps
was fitting my act meter yesterday and noticed oil in the crossover pipe etc. so checked the turbo for play. the shaft moves but only approx 2mm. does this mean the turbo is on its way out!!!
ta
davie
ta
davie
theres a certain amount of oil residue that builds up in the turbo pipes
i dont think its much to worrie about, does the car smoke or hold back??
if theres oil gettin past the seals it will smoke like a gooden!
sounds like theres abit of play there but some of it will be taken up once theres
oil pressure there.
if im wrong feel free 2 give me a kick in the arse
oil pressure there.
Sounds normal IMO, as above is the car running ok? IS it side to side play? this should be minimal but a tiny bit is normal, is there any in / out play? that is not supposed to be good! And as Dickie say's there will be minimal oil in the pipes, but if it is slicked, that is not a good sign!
Adam.
Adam.
cheers guys
it doesn,t smoke or hold back (at when its going anyway ) and their isnt that a huge amount of oil
so hopefully one less thing to buy/sort/bodge/batter/break.
now where that 6kg persuader
Thats the reason why im swapping my turbo round. Play in the shaft & oil in the hoses, plus its smokes like mad on cold. Smokes the whole road out. Well i hope its the turbo, as ive got one on its way.
JK12
33
26-04-2021 12:09 PM
