Rs Turbo S2 Running Problems Again
Put the car back together and ran fine. But tonight I went for a drive and found the car seemed to hold back. Got back home and found the car to be breathing heavy, as when I took the oil filler cap off which pops off now and again the car doesn't die. It seems to be pumping quite a bit of pressure out of the crankcase pipe that attaches to the the top right of the rocker cover.
There also seems to be quite a bit of oil in the boost pipes.
Also there is oil coming out of the in car bleed valve when boosting up.
Any ideas?
Dave
Any ideas?
Dave
Found the problem. Ran a compression test yesterday and found No4 to be well down on compression. I think I have got some wellseal caught up in the rings so they are sticking. Hopefully anyway.
Stripped it and found the piston to be cracked. Gutted. Only marked the barrel slightly so I might get away with it. Took some pictures. What do think?
Got an engine lined up which I should be picking up tomorrow then I can re-build this one to a much better standard uprated pistons, cam, lightened flywheel etc at my leasure. Which will be alot better.
Dave
Dave
big_Rad
15-09-2017 09:36 AM
Zoggon
10-08-2015 10:39 AM
