gearbox oil
the box has been out now and is completely dry...
do i need any diferent oil because of the lsd?
i dont wnt to fuck the box up as its my first rs and dont have a clue can someone please get me a link to a suitable oil please so then it will put my mind at rest
thanks
Ive always used Fully Snth Mobil oil, costly @ around £12 per litre but the box has always been perfect with it. If it is bone dry, i would advise to pour some through the overflow pipe (tricky) also otherwise you will not lube up the 5th gear properly.
the diff uses the same oil as the rest of the box, fill the box up till it starts to come out the filler hole, go for a slow drive and use all gears, then top up again if needed, buy a 5 litre tub of gearbox oil, the box takes around 3.5 iirc so you will have 1.5 litres spare just incase you spill any or need to top up
TPM961
15-01-2018 10:50 AM
Adam Graham
06-09-2015 06:04 AM
