Oil pumps
Oil pumps
Rite went to see the block whos rebuilding my engine yesterday, found out it needs a rebore and new pistons, makin the engine a 1650, i was wonderin seen as all the internals are gettin replaced, am not goin for big power or anythin, but was wunderin would it help to use an uprated oil pump? or would a standard one be fine to use?
thanks ben
thanks ben
Parts Restoring Nutter
Hi Ben
Who's doing the work for you matey??
Definatly go for a genuine ford oil pump pal as all these uprated copy
ones fail. Oil pumops are the heart of the engine and thats the last thing you
need after a fresh rebuild. Ebay is littered with copy ones for £60 etc
aswell as burton power but steer well clear.
Genuine Ford all the way
Part No's below
CVH pump upto 1986 - 6085097 - Gear type
CVH pump 1986 on - 6169335 - Rotor type
Oil pump gasket - 6851352
Oil Pick up pipe gasket - 6169337
Oil pump bolts - 6103425 x 6no
cheeRS
Chris
Part No's below
cheeRS
Chris
Hi Ben
Part No's below
cheeRS
Chris
Part No's below
cheeRS
Chris
wheelwizardrefurbs
23-09-2015 09:21 PM
