serria cossie turbo will in fit erst ?
Old 04-05-2009 | 04:58 PM
andyjg79's Avatar
andyjg79
Default serria cossie turbo will in fit erst ?
freind of mine has gave me a turbo of his d reg serria cossie
looks completly differant to mine as the actuator flap is biult in to the housing would i be able to remove the turbo and fit to my old manifold and housing
many thanks for any help in advance
still blowing smoke after full engine recon replace every thing with new except turbo play in the shaft didnt seem that bad
belows smoke from cold white / grey slit oil signs
clears up when warm still smokes slightly on boost
also had bad fuel put into it to get it home as it had been stored for 2 yrs
with out running
any surgestion as i am pulling my hair out now
Last edited by andyjg79; 05-05-2009 at 06:59 AM. Reason: need help will cossie turbo fit erst ?
Old 05-05-2009 | 09:00 AM
wilky's Avatar
wilky
turbo will fit mate just take off the turbine housing's and swop them around
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
carlo
24
05-10-2015 08:20 PM
marky_g
15-08-2015 10:43 AM
Quick Reply: serria cossie turbo will in fit erst ?
