right im confused i have a xr3i gearbox in my turbo its a efi engine with 195 chip biege injectors std intercooler and made 169bhp at totd but when i drive it it revs very high for the speeds im doin its bout 6000 revs at only just over 100mph is this down to the gearbox or is it something else just want to know if a turbo box would help my cruising speeds ??????????
well standard figures say 127 but mines chiped and bigger injectors so was hoping for at least that but its imbarressing when vans are beating me on motorways
so wat does the rs turbos use who have top speeds of over 130 ? how much power do they have if i upgrade to 200ish bhp would i still have the same top speed ???
possibly abit more yeah, but its all about power bands too, i mean you've got to be pulling close to 6k revs at those speeds, and how much useful power is up there?
If your speedo is correct (which you say it is) then it can only be down to gearing, 100MPH @ 6000rpm is not right if your in 5th!!!! Are you actually doing 6000rpm or is the Rev counter faulty maybe?
well i think its right but it feels like its got more to give but dont want to ruin my engine as its reving so high how can i make sure its showng true revs
Think it's 950rpm idle, but even if it shows idle correct it might not up in the revs, I had one that would only get to about 2500rpm! Obviously the car kept going was just the needle that didnt get any higher!
sounds like a combination of things you.ve probably got a early xr3i box in with the 4.29 final and possibly got a speedo that is reading right as the old xr3i on standard wheels used to read around 120 at 6000 take away 10% inaccuracy and your back to 108 not that far from what you.ve got given the rev counter could be out 100/200 rpm at that stage your probably back to what your reading. bang a series 2 box in it and you'll notice a big improvement 100mph a touch over 4250 rpm
But i have had it of the clock on the motorway 140+
Gonna get the lsd gear box tho to much wheel spin
wat spec is your engine as im tryin to work out if its the gearbox or something else i know the gearbox is not going to last long but its not broken i dont want to spend money on something i dont really need
I have heard 'stories' of peoples XR3i boxes lasting really well even on cars laying down 200+BHP!! You might be suprised, I think it's all about the hard launches really.
and mega revs.
if you keep thre revs sensible then they seem to last alot longer.
but wheres the fun in that braaaaaaaaaaaaaap tish braaaaaaaaaaaaaaaaaaaap tish
i heard the standard gear box wud limit out at 140mph. i have had mine to 130mph on a air feild of course lol. but there was brown stains on the seat haha.
just wundering what gear box's are ther to get better top speeds and to run more power throgh.
sorry for the hi jack mate.
wouldnt mind knowing to i know the mtx75 box is meant to be good 60mph in second !! but does it cope with the power?
ive got s1 ratios in my fiesta turbo and i can pull 154mph on 15"wheels .
I always thought S1 ratio's were short? I had what I thought were S1 ratio's in mine YEARS ago and used to bounce off the 5th gear limiter in well under a mile.
wat have you got in yours now wat spec is your box?
