LSD BOX clonk clonk!
Need help!
When i select reverse in my ERST and start reversing back there is a nasty loud clunk clunk clunk noise coming from the front end and the car shakes about as its reversing seems to be worse when u lock the steering over. Ive had a few people say its the LSD but i have just had the box rebuilt for the second time with a new diff and it still makes the horried noise. Anyone got any ideas what could be the cause of it??
Well ive replaced all thr bushes with poly ones and the drive shafts are brand new ones i bought about a month ago and this still did not cure the problem?
The drive shafts are in properly, the noise seems to be coming from the g/b area, i wondered if the clutch could be failing.But surly it would make a noise when going farwards to?
It only seems to judder when going backwards. I did not do the work on the gear box so i did not see the clutch .But the mechanic that did it would have cheaked it i would have thought.
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
