Removing the black underseal in the wheelarch--SERIES 1
Chasing Radders
THINKING of removing the underseal in the wheel arches of the car as i love the white look through the wheels....Justseems to make the cars look even better
BUT
Does it take some taking care of once removed???
HOw hard is it to remove???
BUT
Tiff use a blowtorch and scraper to get most of it off then a wire brush on your grinder to clean the rest up.
Either use a white stonechip or you could use hammerite
Don't remove the sealer unless it is already coming off Tiff. Just peel the bit that is coming off and re seal it then clean all the rest up and paint over it with plasticiser so it stays flexible.
As long as you clean it up properly with panel wipe but it might be easier to take it all off and freshly seal it and then paint it.
The easiest way to remove it is to warm the panel up from the opposite side with a heat gun and the sealer just peels off then. This means interior out though.
Si B
12-09-2015 06:49 AM
grishenko45
09-09-2015 12:58 PM
