spark plugs
12-09-2006, 10:07 PM
spark plugs
does anyone no the plug gap for denso iridium plugs
12-09-2006, 10:19 PM
depends on boost. 0.65 is a good place to start.
12-09-2006, 10:25 PM
it peaks about 15 them drops to about 12-13 psi
12-09-2006, 10:30 PM
id go for 0,75mm then to start with, and close them up if u get a miss - v unlikely that you will.
12-09-2006, 10:32 PM
Hi,
99% certain they are pre gapped What is the part number
Dave R.
12-09-2006, 10:33 PM
hi i think it is Ik 22 i will have to take 1 out and have a look
12-09-2006, 10:36 PM
Denso are pregapped. At 15psi u will not have a problem. in my experience, it's when u go over 20/21 that the ign system is really tested.
12-09-2006, 10:39 PM
do you no what the pregap is because i have set them to 0.8mm thanks
12-09-2006, 11:15 PM
not for certain, but i would bet on around .75
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
Brickhouse
14
03-10-2015 07:28 PM
deathrider666
28-09-2015 06:12 PM
