IS THERE A GASKET BETWEEN THE MANIFOLD AND THE TURBO
07-09-2006, 01:09 PM
as above
07-09-2006, 01:16 PM
you can get them but I've never used one...
07-09-2006, 01:45 PM
Don't mention ze Vor
Don't have one fitted either.
07-09-2006, 02:08 PM
Some do some dont i used one on mine as it kept blowing from there dont think they came standard as not all cars have them....
jon
07-09-2006, 03:02 PM
just ordered one off egay because mine was blowing.
07-09-2006, 04:29 PM
use the metal job from your turbo supplier and seal it up with a bit of firegum , just ensure your faces are flat and true.
any other type of high temp gasket simply burns and blows
07-09-2006, 05:12 PM
no need to do anything.... just make sure both faces r dead flat n bolt together....
them gaskets r shit... i blew 2 of them so went bk to NOT usin em
07-09-2006, 10:33 PM
08-09-2006, 03:38 PM
no there is'nt one from the factory and you dont need one anyway
08-09-2006, 03:48 PM
08-09-2006, 03:51 PM
Not from standard, if its blowing have the manifold and turbo faces skimmed, and it will be like new again
08-09-2006, 08:18 PM
They blow real easy,As long as ur faces are prtty flat u shouldnt need! I smear a bit of copper grease on the faces to help em seal...never had a problem!
09-09-2006, 12:48 PM
Got my gasget from local ford dealers spare department, cost pennys mate!
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
kevin36
02-09-2015 06:24 PM
mint_s2
02-09-2015 08:58 AM
