Cosworth Brakes
Cosworth Brakes
Hi
Will 2wd cosworth front calipers/disc fit onto mk4 hubs?
I've seen you use 4wd calipers and 2wd disc but not seen anything about running 2wd calipers and disc together?
cheers
cheers
they will but you need to get some metal shaved off the hub/caliper to get them to go on (I've got them on my RS)
I can't remember off the top of my head how much, Ryan on here knows though
ok heres 1 for ya.
I know if i buy cossie discs I can buy a dracket and keep my S2 calipers.
but if I was to use 4x4 calipers and a 2wd disc would I need anytype of bracket or would it bolt up to the standard erst stuff?
cheers
cheers
Originally Posted by scottbrown
ok heres 1 for ya.
cheers
cheers
This combination will go under standard rims, 2wd calipers however won't
Well i think u need the 4wd hanger aswell, but apart from the washer they bolt straight on!
2wd calipers should be better in theory, as they are 4 pots.
yeah but i am a cabbage so was looking for sommit to bolt straight on with out have take take metal off the calipers and tap bolt holes
so are the 4x4 a pretty straight fit?
If you want to do a 2wd set up u could buy some discs and bells with the correct offset so you don't have to machine anything. And tapping the holes in the hubs couldnt be easier, they are already 10.2mm which is the hole size needed to tap an M12 thread
so what are bells? and where from please?
Basically, you buy the disc part, and can get different offset centres that bolt to the disc to space the disc accordingly. Most places that sell the likes of AP Wilwood etc calipers will also sell them
what about granda cosworth calipers? i believe they are 4x4 fronts and sumit elese rears, not too fussed abouth the rears just want to know abouth the fronts!
Red_bull
09-08-2015 08:34 AM
