revs drop
revs drop
when i remove the oil filler cap on my escort rst the revs drop and the engine cuts out, what causes it sum people say its a blocked breather others say the rings r worn.
Custom
Originally Posted by turboben
now im worried as mine does not even drop in revs when i take my oil cap off
have you got aftermarket oil breather eg bailey ? only the original oil breather does this because it vents the oil vapour to the airbox and when you take the oil cap off it lets air in
If it doesn't cut out:
It either has worn rings/bores creating a lot of blow-by, meaning that air is not leaked in from the cap, but rather exhaust is leaked out.
Or it just runs really rich, so when it goes leaner because of the leak, its just spot on.
TPM961
15-01-2018 10:50 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
