2.1 zvh
2.1 zvh
I am building a 2.1 zvh just wounding was bhp roughly it will be
Forged pistion and steel rods, cr 8:1 ,big valve stage 3 head with Kent cvh35 cam and pulley, t3 cossie 4wd turbo I am running OFAB at them mo but was thinking of trying OFAM with 803 injectors any advice will be much appreciated especially on the management side thanks
mine is running 218bhp at the wheels at 18psi, its a simmilar bottom end to yours but only a stage 2 head but with newman cam, im running siemens injectors out of a rover 220 turbo, they are 440cc flow @ 3 bar, im using emerald management and a stage 3 t3, the only fault with my setup is the turbo is too small, spins up nice and early but its all out of puff at 4500rpm
Spend some money on the head. A stage 1,2,3 is jigged to work with a CVH not with the Zetec bottom end. Most ZVH builds run out of guff about 5500rpm as the power and torque just vanishes
