1.8 zetec into s2 rst
i have done a serch but have not found what i am looking for. so any advice info will be awesome.
i have just baught a s2 as it was agood price after ditching my mk6 project due to rot!
i have a 1.8 black top from a ford focus all ready turbo converted. i am looking for a guide on fitting this in to the s2 rst if there is one if not i would like to gather as much info/tips as i can. i will put some pics of the car and progress up also
thanks in advance
Mikey
thanks in advance
Mikey
hi!!! its a easy conversion!!! but you have to make some changes.. if you want the easy and fast way get a rst gearbox and clutch put it on your engine with the 1.8 pressure plate make sure both are 220mm right there you have youre gearbox mount for the s2 then the engine mount of the s2 bolts right in to the 1.8 block last thing find hoses and radiator that fits best.!
hope that helps!
hope that helps!
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
