Driveshaft problems!
Aug 5, 2012 | 06:52 PM
Ive just fitted my rebuilt gearbox with an uprated "ricardo" atb differential, got everything back together and the driveshafts don't fit in the diff. They are too small and the teeth don't interlock. So does anyone know what inner CV joints have bigger teeth than the stock ones?
The usual inner cv's measure 25mm across the teeth, i need 28mm ones...
Help please got a rolling road day soon and ford fair next weekend!
Aug 5, 2012 | 07:32 PM
You should ask "ricardo" (or whomever supplied the diff) should know what fits.
Aug 5, 2012 | 07:54 PM
I have emailed them... Just wondering if anyone had any ideas, maybe mtx inner cv's etc?
Aug 6, 2012 | 08:36 AM
Quaife ATB is also 28mm...
I think you are maybe running a 1.3 gearbox and shafts as IIRC they are smaller?!
Aug 6, 2012 | 10:01 AM
I was running a standard rst lsd gearbox and shafts... They measure up at 25mm
Aug 6, 2012 | 11:49 AM
Yer RS are 25mm, 1.3 are 23mm iirc.
So no idea on what cv's
Aug 6, 2012 | 12:11 PM
I need to find an inner CV thats 28mm and that fits onto my driveshaft...
What size are MTX CVs? Maybe thats what i need?
Aug 7, 2012 | 11:41 AM
Jano had measured an MTX inner CV for me and its 28mm!
What cars had MTX gearboxes, so i can try and track down some CVs or shafts?
Aug 7, 2012 | 12:02 PM
Quote:
Originally Posted by
Rogeyboy
some mondys i think and the mk5/6 escort rs2k run the mtx75 if they are any use?
Aug 7, 2012 | 12:15 PM
So how come my shafts in my s1 fit straight into my quaife atb then ?
Aug 7, 2012 | 06:47 PM
Roscopeco
So do my brothers s2 shafts, they just fit in his quaife diff.
Aug 7, 2012 | 07:39 PM
my standard shafts went in my quaife and in my gripper , will mtx cv's work with rst shafts ?
Aug 7, 2012 | 08:12 PM
Roscopeco
BRAM
The Quaife diagram must be showing the aperture size not the splines I guess?!
stuart collins
No they won't, or you would'nt have to cut and shut shafts to run a MTX box I imagine?!
DAZZER
Sep 30, 2015 08:43 PM
mondeomark
Sep 28, 2015 06:28 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
