Oil return pipe
05-08-2012, 09:18 AM
Oil return pipe
Should the oil return pipe from the turbo to the sump have jubilee clips on?
Cheers, neil
05-08-2012, 10:44 AM
No but I've put them on mine
05-08-2012, 11:20 AM
Quote:
Originally Posted by
darrenb16two
06-08-2012, 09:11 PM
spring loaded clips on mine now.
07-08-2012, 10:57 AM
Balls Deep!
IME Jubilee clips do not expand like the original springs clips and cut into the pipe if done up to tight causing it to split and piss oil everywhere.
07-08-2012, 11:39 AM
As Karlos says...
I had jubilees on mine and it split, ive you do use them dont do them up tight theres no pressure (other than crankcase pressure) in that pipe just a steady return of oil back into the block/sump
07-08-2012, 05:31 PM
Thanks for the advice, I've put jubilee clips on for now as it was leaking, I'll have a look at ford fair for some spring clips, anyone know what size?
Might even treat it to a new samco pipe
Cheers, neil
07-08-2012, 06:05 PM
Can't help with the size, however they are fitted on the orig mfi breater set up, thats where I got mine from.
07-08-2012, 07:52 PM
P8 Managed S1 with ALS
studabear
+1 on that stu thats where i got mine from
07-08-2012, 08:14 PM
I've got a bailey breather set up on mine, still got the old one in the garage so I'll rob them
Thanks again, neil
155lee
27-10-2015 04:55 AM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
PeterLucas
21-09-2015 11:36 AM
Chopshop85
18-09-2015 06:13 AM
Rich Coveney
Ford Mondeo Including ST
15-09-2015 05:39 PM
