2.1 zvh turbo
2.1 zvh turbo
More advice needed... I took out my escort zvh turbo the othe day for the first time after almost a year of building it .and noticed when I drove it up the road it was making a
Knocking noise which sounded like the drive shaft I was only going very slow in 1st gear
.ive since jacked up the front of the car so the wheels are off the floor and started the engine when I put it in any gear and let the clutch up it seems to make a rumbling and slight vibration noise from the front only when in gear ..Any Ideas??
Actually im not sure cos when I was driving I was going up hill so I didnt freeroll with the clutch in to see if the noise went...
Its weird cos when I tried it with the wheels off the ground I didnt notice the knocking ..dont km now if it makes a difference but I had too change the passenger side driveshaft for a longer one .cos for some reason the original was too short and kept pulling out of the cv/ knuckle joint on the gearbox side of the shaft..??
JK12
33
26-04-2021 12:09 PM
