Dump valve
Old Jul 30, 2012 | 05:32 PM
slimwynn's Avatar
slimwynn
Default Dump valve
My seals on my turbo have just gone I was wandering would running 15psi and no dump valve be the cause of them going or is it just ware and tare?
Old Jul 30, 2012 | 06:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Wear and tear mate, I ran 32psi on my last CVH build with no DV and had no problems.
Old Jul 30, 2012 | 06:12 PM
slimwynn's Avatar
slimwynn
32Psi lol I'll be fine then I can stick with the chatter
Old Jul 30, 2012 | 06:48 PM
mgtkr1's Avatar
mgtkr1
with a good quality turbo esp with a 270/360 bearing i think theres little need to worry about wear as a result or no dv. most people use a dv down to trend, rather than any technical reason albeit dv sales patter is usually ''protect your turbo''. i cant stand the sound, and for confirmation ive looked at pics of some big boost cars and noticed a blank/no dv. if karlos has had no problems with 30 odd psi then that settles it. same with a few other well known cars.
Old Jul 30, 2012 | 07:04 PM
stuart collins's Avatar
stuart collins
i run a dump valve and its not for the noise
Old Jul 30, 2012 | 07:10 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes but you don't run a T series turbo do you Stu?! lol
Old Jul 30, 2012 | 07:12 PM
stuart collins
nope..
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
