Radiator and intercooler set up
I've got a Pace rad and a Radtec intercooler with a big single fan at the front along with a 82 deg thermostat, but try and fit fans in between the rad and intercooler works better.
I have a zetec s thermostat in there and at the minute I have twin spal fans but the last time I had my fans between the rad and intercooler the heat burnt them out
Ive got a radtec ic and an airtec rad, both alloy obviously... Twin spal's on the front of the IC and the temps rise to 96/98 on the motorway (so the fans are on) and sit there!
If i sit in traffic the temps go up to 96/98 and sit there and don't come down!
I think ive got an airflow issue!
I'm going to put another set of fans on my radiator. Do I need to have fans on the intercooler as my front bumper is cut out so the air hits that straight away ?
struggling with reality
Standard radiator and big pace cooler. The normal ford fan on the radiator. I have a separate rad for my turbo and water cooled exhaust valve guides. My fan is on a ford switch for the RS turbo which comes on 2°C lower than there normal ones (was told this by the guy in the parts dept). I use water wetter in my coolant.
My Fiesta never gets above halfway on the temp gauge unless, I am racing on a track, or I am in town and the fan is not working (happened a few years ago). Even then does not get into the red! Possibly over cooled but I haven't finished with her yet, as I want to add N2O !!!
You do realise that the pace half cooler is as much use as anne franks drum kit.. it barely cools better than standard
Mine is a converted 5DR i will have a look for some pics now mate! i know i had to "modify" the tabs shall we say on the radtec cooler to make it sit flush with the fan
Heard that about the pace one . So I Orderd a airtec double one .
i have never been a fan of double stacking the rad and intercooler and thats why i rebuilt the front of my fez and build my own turbo pre rad, main rad and intercooler.
p-s not tested the setup yet!
Here's the Airtec rad and Forge intercooler that was already on my car when I bought it last year, they bolt perfectly into the standard location:
The coolant temps are fine but Ive not got a clue about charge temps?
Anyone familiar with this Forge cooler?
Hi mate how much you wanting for the IC and fans?? I'm running standard rad and shit pace IC at the min and thinking of changing it?? Would I have to change the rad too?? Cheers Ryan
Wye Valley Hardcore
If there's a gap the air might not be forced through properly. I tried a fiesta alloy rad on mine which was too big and left a gap between the cooler and rad due to my intercooler being mounted in front of the crossmember not on top of it.
Cooler setup :-)
My setup is a Airtec Black series water cooler and a Radtec front mount intercooler . Not sure where to put the fans yet? Currently they are in front of the intercooler...
The inlet is not finished yet. The trumpets on the picture was a test mockup. But I think I am going for a Jenvey Turbo plenum. Like this one:
