helppppppp please
Old Aug 15, 2012 | 11:05 AM
lee s1's Avatar
lee s1
Default helppppppp please
hi all i am in need of some help with an issue on a s2 Here goes
The car will start and run fine from cold then once hot it looses power and starts to black smoke from exhaust Having had a quick poke round i have found if you un plug the black box on the right hand side of the meetering head the miss fire goes as does the smoke and drives fine plug it back in again and fault returns let it cool down and its all good again untill it gets hot any ideas as to what is causing this fault
Thanks in advance lee
Old Aug 15, 2012 | 11:46 AM
Karlos G's Avatar
Karlos G
Balls Deep!
That's the EMFPA, it controls your fuel pressure and is what gets adjusted on a setup... They often drift out and it sounds like yours needs adjusting.
Old Aug 16, 2012 | 08:37 PM
project rs's Avatar
project rs
it sounds as if your box is thinking your on boost when not and giving you the required fuel for it but as your not it's overfuelling giving the black smoke time for a set up
Old Aug 16, 2012 | 08:42 PM
stwibs's Avatar
stwibs
Coolant sensor on inlet manifold
OrionRST200bhp
43
Sep 14, 2014 05:54 AM
marky_g
Nov 3, 2013 05:48 PM
bigalcossie
Jun 17, 2009 11:38 PM
Dan Cossie
24
Feb 8, 2007 03:02 PM
Physio
82
Oct 18, 2006 04:18 PM
