Mk1 focus 1.8 tdci cam belt tool
Fleet Manager
Need to buy one but have no idea what in looking for!
Bloke I work with says they just look like a few bolts but when u google it there loads of different looking things
Helppppppp
Helppppppp
the belt just goes between the cam pulley and the inj pump,(theres a chain from crank to pump)
you need to take the rocker cover off and theres a flat platet that goes in at the back of the camshaft to time that
the pump is as mentioned just a pin(like a bolt), or just use a bolt the right size
you can do it without anything fancy, bolt i the pump and spanner etc in back of the cam
if your brave enough you can just mark the pulleys with tippex/paint etc and not bother with anything
they're very easy to change
I dont think there is a pin for the pump on a tdci.
i normaly just take the covers off
put the flat plate in the back of the cam
put a tipex mark on the pump
loosen the bolt on the cam pully but dont take it all the way out
give it a gentle tap with a hammer to free it off
then loosen the tensioner and take the belt off
Fit the new belt and tensioner
tension the belt then tighten the cam pully bolt
turn it over by hand a few times and make sure its all timed up
then covers on
then covers on
there is a bit ti pin it up just like the tddi, but the pump itself obviously doesnt need to be timed,
i do it the exact same way you said tbh
I am thinking of replacing the cam belt on my 59 plate Mk 2 TDCI Focus. Will it be the same? Not sure why you state "leave it loose while you tension the belt or you can put some slack in the timing chain which will shred the timing belt in a few miles". Can explain why please?
thanks
thanks
