need some help please (ignition timing)
Hey there i have a co problem and its sky high its a 1.6 cvh engine running l8 cosworth management and my question is.. On the crankshaft pully where should you set ur ignition timing too? The usal place on ever rs turbo or should it be beside the new crackshaft sensor as that is now further forward any help would be great cheers alan
The ecu sets the timing on cossie management, are you using a phase sensor on the cam pulley or a modded dizzy? If a phase sensor set up on the cam pulley just have the dizzy in the centre of the adjustment.
Im using the phase sensor yea if i move the dizzy it does nothing to the ignition timing but the pick up on the crank pully was moved before i got the engine and i moved it about and that does move the ignition timing but not much. I can get it almost half way between the 0° on the plastic timing matks and the crank sensor so its far advanced can anyone help me out abit cheers
van_dogg_pavvy
03-03-2016 09:30 AM
Zoggon
10-08-2015 10:39 AM
CabrioTurbo
01-08-2015 11:04 AM
