engine noise! almost given up
hello all, im having trouble with my newly built rst. its an mfi engine which has been fully rebuilt. crank re ground all new shells, rings ect. new waterpump. oil pump belts, dizzy ect. now the problem im having is that when the car is underload it makes so much noise.. like a very loud tappping, iv just put another gearbox on thinking it could be that but has made no difference. it has a brand new clutch and skimmed fly wheel too. could a new cam and lifters be the answer or does anyone else have any idea what else could be making the noise. its only when driving along when revs get high that it does it not really noticable on tick over.
fully rebuilt but not the cam? if a new cams died already thats not too good. what grade oil are you using ?
could it be valves not seated properly? or maybe something loose was left in the valve cover or it the sump and at high revvs it rattles against something else??? happened to me when i snapped the timing belt on my old fiesta i forgot a nut in the valve cover and at high revvs it made a lot of noise.......... also could it be the fuel mixture isn t correct and it rattles cause of that? don t know just throwing ideas around......
Balls Deep!
It takes no time to whip the sump off and check your big ends, I would do this if keeping your oil at maximum doesnt help.
What oil pressure are you seeing at idle and at 3000rpm after a 30 mins drive? Oil should be fully synth 10/50 if you didnt know.
just curious to what grade oil your using? if the right grade id check the big end bolts havent come loose..(but from past experience that would be noisy all the time )
I'm thinking oil starvation at high RPM, I noticed on my CVH that at sustained high RPM my oil pressure gauge surged if I was below the maximum on the dip stick... Doesnt drain back down fast enough... Then I spun a big end bearing! lol
Don't do this, as you said you've tried two heads/cams so that points to the bottom end sadly... If you can hear it knocking then you may have ruined your new shells/crank.
Balls Deep!
Cams/lifters very very rarely tap loudly and if they do it's down to low oil pressure... Even when I have had the lifter bases break up and fall apart they still didnt tap/knock because they are hydraulic and take up the slack.
Have you meassured the crank before fitting any of those shells? What was the condition of the ones you changed again?
+1 for ignition timing (not to be confused with cam timing). Turn away from bulkhead (as in undoing a bolt ie to the left if looking at the cap). Just a few mm and try it again. However, if it was so far advanced you would probably be having starting issues and it would seem like the starter is not strong enough to turn the motor.
Balls Deep!
This is for stock boost though, if you are running more then set it at 8DBTDC to be safe!
IMO if it was detonating bad enough to sound like a knocking engine you would have cracked a ring land by now, but well worth checking all the same.
Does it sound anything like this?
You need to check it is at 12BTDC with a timing light, unplug the vacuum hose to the ECU and block it when you do it.
Ok... Could you post a video of it knocking? Get somone to rev it a little whilst you take it, might make it easier to diagnose!
Does it sound anything like this? http://www.youtube.com/watch?v=rNysSrpFTHc
That's my old engine, only just replaced it last weekend. It was the bottom end, haven't taken it apart yet, but I was told ring lands. I'll take it apart tomorrow.
am having the exact same problem with mine at the moment only does it under load it sounds like engines gona fall out,.......read my post... if u find out a solution please tell... if its like mine its not engine. i suspected clutch release bearing but who knows got to just have a stab at things i guess
yes mine makes the noise only when driving. not just at high revs but at any revs going through the gears. my clutch release bearing is brand new as is the clutch. i noticed last night after i adjusted the ignition timing i took the car up the road and when i got it bk in the garage it was very hot!! water was boiling. whats happend there??
might be water pump then because i am loosing water too and head gasket is fine might be both are problems dunno tho i wud of thought it wud of done it all time but maybe only does it as its trying to feed more water through i dunno its pissing me off i bought a new engine mount and made it worse lol
