need urgent help plz
hi there i took my escort rs turbo out yesterday an i gave it gd blast up the bypass an wen i slowed down i herd a tapping noise? then after a few mins driving normal down the road it was gone? later on i gave it some again an then the tapping noise came back again?
today i started the car an the tapping noise was ther again wen i rev from between 1000, 3000 rmp the tapping is ther but if i keep my foot on the throttle at 4000 rpm the tapping is not ther? wat cud that b?
the tapping noise is cuming from the right side of the top near dizzy but i checked near ther i seen a bolt missing from the manifold i have replced that but noise still ther cud it b the manifold gasket?
if anyone got ant suggestions plz help cuz ford fairs round the corner thanks
do you run a gasket between the turbo and manifold? they are garbage and should run face to face. i used a gasket here that failed the 1st time i gave the car berrys.. if not id suggest the ex manifold (ex to head). alternatively, could be tappet related
Ive just bought a s/s tublar manifold which Ive been told needs one though.
just been out in it now
just took the s2 out on the motorway an it was tickin noise ther but wen i go over 4000 rpm it goes away how odd is that an wen i drop gears ther is no noise only wen i put mt foot on throttle??????????????????? an it dont make that much tickin noise on idle?????????????????????? plz help
if it comes from beneath the rocker cover, then whip the tappets out and look for signs of a sticky one. you can squeeze them in a vice to free them. oil sludge can sometimes give the tappets problems. you could also try flushing the engine but i have reservations about this. do you know if the engine oil has been changed regularly?
with the std cast material, the manifold/turbo expand at the same rate maintaining a seal. as s/s and the cast material expand at different rates id guess that a stainless manifold would req a gaskets.
tappets
i have put new tappets in an the tapping noise is still ther can any one help? or cud it be the manifold gasket????????????????????
An eye for detail...
Definitely worth checking for any wobble in the valves, you can do this without removing head but it'd be better if you can.
If they're worn id look for a reconditioned head and swap all your bits over, can do it in a few hours easy enough.
hi tbh its going to be very hard for anyone to tell you wants wrong with your car without hearing it for them self someones tapping could be another mans knocking or blowing so you need to take it to someone who knows there stuff coz load of people on here are going to try to help and someone mite get lucky and guess whats wrong with it or you could end up changing loads of bits that dont need doing
good luck mate
good luck mate
good luck mate
good luck mate
I can 100% say my valve guides were worn which caused a valve head to fatigue and come off the stem, the tapping was there at idle, came and went between there and 3k where it was silent and wasnt really noticeable above there.
good luck mate
good luck mate
As a final thought, I think someone should make an iPhone app with dodgy noises from cvh engines as a sound board we could have, 1 , tappets 2, bottom end rattle 3, exhaust blow 4, air leak on bottom boost pipe 4, knackered thrush race bearing 5, fucked gearbox!
I could go on unfortunately! But remember the 30 mins a year when your car is running sweet and you beat something much more exotic along the bypass and it's all worth it..... Good luck
