P8 pin for lambda sensor
Old Jul 31, 2012 | 07:49 PM
Mids_s2's Avatar
Mids_s2
Default P8 pin for lambda sensor
Hi I was wondering which pin on my P8 ecu I need to wire in my lambda sensor so I can run closed loop fuelling??
Thanks Ben
Old Jul 31, 2012 | 07:55 PM
paul16v's Avatar
paul16v
Monte 087
http://www.bigturbo.co.uk/
Pin 2 going from this mate.
Old Jul 31, 2012 | 07:59 PM
Mids_s2's Avatar
Mids_s2
Ok thank you for the quick reply, do you know if the ecu will have to be activated or it will just learn from when it's plugged in?
Thanks Ben .
Old Aug 3, 2012 | 09:03 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
What engine is the ECU running and on whose "chip" You will need a custom map more than likely to be able to do what you want.
Old Aug 3, 2012 | 11:07 PM
Mids_s2's Avatar
Mids_s2
Hi Jano as far as I'm aware it's a turbosystems chip and it's cvh,I'm guessing the lambda will have to be activated before it will run closed loop??
Old Aug 4, 2012 | 01:12 PM
Versus_Creations
Ask me a question!
As far as i know Tony wouldnt of done a chip for a FWD setup Cosworth managed car. Its worth asking him on the off chance, i have his number he is also on here.
I guess its a cossie chip which wont work on yours obviously anyway, regardless of the closed loop which could be on or off on the chip.
Old Aug 4, 2012 | 01:52 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
I have mapped many models of car fitted with the weber management
including p8 and pectel p8 encrypted ecu's and pectel als etc etc
the ecu will have been labelled with the chip Id
give me this number and I will check the configuration for you if you bell me on Monday
Regards Tony
07587188434
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
muz
Sep 30, 2015 08:29 AM
stevecfrst1
Sep 30, 2015 05:18 AM
