Twin fan loom.
I have twin fans on my front mount, one wired to the thermo, the other on a switch in the car as the two on the std loom would keep popping fuses.
Looking to change that and I'm sure someone on here had a loom diagram for the fans? Using better wiring etc to replace the original fan loom so I don't have to worry about my fan switch any more.
Cheers.
Cheers.
I have replaced all my fan loom with a seperate new cosworth loom. Fed direct from the battery, you will need to swap either the connections or the temp switch and has the ability to run a switch to run manually.
http://www.ebay.co.uk/itm/RS-Coswort...item257314ed5b
^^ sorry only just saw this reply.
Now the fans were running auto on the thermostat. But with both of them it kept blowing the fuse. That's why I decided to just wire one to a switch inside the car on a separate wire so the original fan loom is only controlling one fan.
I've never had this issue and i'm using original loom and msd upgrade switch.
Maybe another problem causing fuse to blow. Make sure its the correct amp fuse and even up the fuse by 5 amp..
The switch's used have the totally wrong span as well, so in the Cosworth's case the fans come on too early and stay on forever which causes melted fuses etc and even fires, and in the case of the ERST, IIRC, it's the complete opposite lol, in that the fans activate too late and don't stay on for long enough?
To this end this is why an "Uprated" switch should be essential where the fans are concerned imo, certainly in the Cosworth's case from experience, can't comment on the RST'S.
Martin
Even so you need to resolve the issue first.
Martin
As I said in my original post, the newer fans will draw less power than the OE ones, so it's up to you really, but imo it's a very wise idea, you don't need one though if your doing it solely for the purpose of the override switch?
Martin
Martin
I have one fan on the original loom and the other to a switch in the car. Both fans on the loom kept popping fuses, so this way I have one fan to run as normal and if it starts to get hot I have the other one on a manual switch. However, its getting to be a bit of a chore having to constantly check my temp gauge and flick this thing on and off.
Hence wanting to make up something where both fans just work as they should.
Yep, had the same problem on my series 1. Not popping fuses but did melt the fuse box slightly. I also have the air tec 'slim line Italian fans' they fit in the gap lovely but I have my doubts to the quality of Italian electronics!!!.... Anyways. Get some thickish cable 5 or 6 mm and run it from the battery to a relay. Run cable from relay to fans and run fans to earth on car. Use existing fan lives as the switch lines on the relay. Send me pics of relay and I can tell you pin numbers to plug what into if you want. You might also want an in line fuse to stop fires. Good luck
Yes you can martain,my car prove you can do it safely,a simpe 5amp upgrade will be fine but of course if your wiring shabby then don't do it. Replace with new wiring if you worried.
The fact it's blowing, suggests something wrong, ok it may just need uprating due to the additional load of the additional fan, hence me asking what rating fuse it's got.
For example if the fuse is 30A and it's blowing this, clearly something is wrong, as the new fans can't draw more than this, and so by uprating the fuse you are asking for trouble!
Martin
Steve Escos
01-10-2015 06:57 AM
