Escort S2 Engine Problems !!
Old Jul 12, 2012 | 12:19 PM
Escortrsturbo89's Avatar
Escortrsturbo89
Default Escort S2 Engine Problems !!
Hi my name is André and i come from Germany. Sorry but my english is not so Good.
I'm new here and have a big problem with my S2. My Escort has boost but no power. I don't know what it is and despair slowly .... the engine is completely new turbocharger is only the old. I feel like I'm riding on a rubber band. The electronics can have an error?
before the engine has been re-made everything worked. before the engine rebuild I had a boost pressure of 0.2 bar and now I have 0.4 to 0.5 bar.
I don't know if you understand my problem, but maybe you can help me. Thank you.
Old Jul 12, 2012 | 04:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Boost pressure should be 0.5 bar as standard, have you set the timing correctly to 12 Degree's BTDC at idle with the vacuum hose disconnected from the ECU and blocked?
Old Jul 12, 2012 | 04:39 PM
paul-h's Avatar
paul-h
That's what mine ran like before I asked my mechanic to set it up as per what Karlos said!
Old Jul 12, 2012 | 05:15 PM
Escortrsturbo89
No I have not done! The engine was delivered from my engine builders finish. and I have everything connected.
what can I do now?
Old Jul 12, 2012 | 05:37 PM
escoskmv's Avatar
escoskmv
i would run the engine in then take it for a tune. thay will find wots up with it then mate.
Old Jul 12, 2012 | 06:37 PM
Escortrsturbo89
Next week I will check the timing and maybe it works then
when the engine is cold is also often smoke and extreme. when the engine is warm, it runs perfectly, and no longer smokes. maybe that's a problem?
Old Jul 12, 2012 | 07:38 PM
Karlos G's Avatar
Karlos G
Balls Deep!
You MUST set the timing correct or you will be down on power.
What colour smoke, blue, black or white?
Old Jul 12, 2012 | 07:53 PM
Escortrsturbo89
the timing is 12 Degree's BTDC oder?*
der wagen fährt sich so als hätte ich keinen turbolader.
the smoke is white, but he loses no water. maybe gas?
Vincereese
Jun 1, 2023 09:14 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
