Escort RS Turbo S2 not starting after changing fuel filter
Hi,
I have done basic services (Oil, Oil Filter, Spark plug, dizzy cap and rotary arm) on my ERST S2 load of times without any issues, but today it was the service from HELL the additional item I changed was the fuel filter and now the car does not start! It seems like there is no fuel getting to the injectors.
I checked the following;
· I checked to see if fuel was coming into the new fuel filter by cracking the top banjo off and fuel came out.
· Next, I checked to see if fuel was getting to the injectors by cracking the 4 banjo nuts on the metering unit and then starting the car, again fuel came out
· Also, when I started the car the metering unit paddle goes down about 5mm.i also tried pumping the paddle whilst starting the car...nothing still wouldn’t start
· Then check if the fuel pump was priming, and it was (now I’m panicking )
· Finally I checked to see if I was getting a spark from the distributor to spark plugs and four where sparking as accepted
Is there air in the fuel system because I didn’t top up the fuel filter with fuel before replacing it?
I tried starting it for about a minute but the battery was giving up and it still wouldn't start!
Please help!
Thanks in advanced
Mission ford fair 2012!
Please help!
Thanks in advanced
track.focus'd
12-08-2015 05:53 PM
CabrioTurbo
01-08-2015 11:04 AM
Escortdriver1
31-07-2015 02:36 PM
