efi pic request
Old Jul 28, 2012 | 07:28 PM
baggy1979's Avatar
baggy1979
RS geek
Default efi pic request
Hi all im in need of air filter pics from those running efi to see how you have plumbed it in and which filters your using also for those using fiesta rs charge carrier pipe which top boost hose are you using as the s2 one is too long to fit the fiesta charge carrier many thanks guys.
Old Jul 28, 2012 | 09:10 PM
studabear's Avatar
studabear
mine uses a cossie throttle body and modded s2 charge pipe. Air filter i have a mushroom type plumbed onto where the metering unit was.
Old Jul 28, 2012 | 10:04 PM
darrenb16two's Avatar
darrenb16two
Mines got an autospecialists filter and a modded S2 charge pipe
Old Jul 29, 2012 | 05:32 AM
gus's Avatar
gus
heres mine, itg panel filter for a ginetta
Old Jul 29, 2012 | 06:03 AM
nigel b's Avatar
nigel b
I'm using a cossie k+n
On the frst charge carrier I cut mine shorter so the hose fits better
Old Jul 30, 2012 | 10:09 AM
Rogeyboy's Avatar
Rogeyboy
I cut the fiesta rst charge carrier down also, so the s2 boost hose fits...
Then i used the s2 turbo to metering head hose to mount my airfilter on the inner wing.
Old Jul 30, 2012 | 09:01 PM
wedge07's Avatar
wedge07
heres mine bud
i didnt cut anything i just squeezed s2 boost hose right over charge carrier, was dead easy, s2 hoses all around and pipercross induction at bottom of the bay
Old Jul 30, 2012 | 09:07 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Pics of mine mid build
Old Jul 30, 2012 | 10:43 PM
Borry's Avatar
Borry
I've got a standard fiesta charge carrier and S2 hoses but with and extra 45° alloy joiner between the top boost hose and intercooler. Oh and it's a cosworth air filter I've got on.
Old Jul 31, 2012 | 10:41 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Always makes me smile that one. Good idea too cause you can feel the pressure of air driving around with the fan switched off, loads of fresh air gets blown through the centre vents so must be plenty to breath for a filter.
Need to see it in person.
Old Aug 1, 2012 | 05:14 PM
kurdt5's Avatar
kurdt5
mine
Old Aug 1, 2012 | 07:28 PM
baggy1979's Avatar
baggy1979
RS geek
Hi guys a massive thanks to you all for the pics this is whats needed for reference.I forgot to mention i have a airtec first generation rad & cooler package its interesting to see some of you managed to use a s2 top boost hose with fiesta charge carrier.I was going to buy a fiesta top hose but now ill have another go with the one ive got. Thanks again.
Old Aug 2, 2012 | 05:42 AM
wedge07's Avatar
wedge07
The only hose i couldnt get to fot was from throttle body to charge carrier, had to use fezzy one
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
