wheres the idle valve?
08-08-2012, 06:56 PM
where is this on the EFI engine? my revs are sat on 950 and need to be upto 1000 as its almost stalling.
thanks
08-08-2012, 07:17 PM
Left of the thorttle body , has a air hose that goes to the charge pipe
08-08-2012, 11:24 PM
An eye for detail...
if its sat at 950 it shouldnt be nearly stalling?
09-08-2012, 06:33 AM
Quote:
Originally Posted by
AstoN_B
That's where it should be sounds like the fuel to air mixture is wrong . Take it to get setup
09-08-2012, 08:04 AM
Thats what i mean, my efi idled around 920ish even with piper cam in it.
09-08-2012, 08:33 AM
Yup my efi idles between 850 and 950 depending on temperature/load.
I was wondering what you were going to do having located the valve because as far as I know they aren't manually adustable
09-08-2012, 09:23 AM
matthart
i went for a set up but they said the fuel ect was ok....
i never realised you cant adjust it............i have kent cam, lifters, adjustable pully....engine has only done 825 miles from being rebuilt.....
can i get the timing set at a garage or does it have to go on the rolling road?
09-08-2012, 02:31 PM
Balls Deep!
The only thing you can adjust on a EFI setup is the idle CO and base fuel pressure so no you can't adjust your ICV... And as said your idle RPM is fine, if it's nearly stalling it must be something else.
09-08-2012, 05:05 PM
Karlos G
What should I look for?
01-11-2015 06:53 PM
15
07-10-2015 03:43 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
routemaster
07-09-2015 05:27 PM
