engine adjustement after rebuild
hy
after my engine rebuild
how is the best method to adjuste the engine
it is very hard to start and when it is running there is very mutch black smoke at the exhaust
my ignition distruber is in the middle of the 2 screw
my CO i dont no where i am with the screw because i played a lot of time with this screw and now i dont know if it to rich or lean
well thanks
all my sensor are working korrect
well thanks
normaly the co screw how can i have a standard adjustement
like i have to turn it full clockwise and than how many turn i need to turn the screw back to have a standard adjustement
and with a stage 2 turbo what CO i need thanks
(sorry for my english)
YES I KNOW I CANT SPELL
you comment saying there is lots of black smoke but dont no if its rich or lean!!?? take it to a tuner! a co meeter is only good for setting the co at idle you have no way of knowing what the fueling is going to be like untill you check it with a wide band lamba of some sort!
as for the distributor you need to at least set the base ignition with a timing light then work from there
jessie_rs
11
03-06-2019 04:57 PM
track.focus'd
12-08-2015 05:53 PM
Zoggon
10-08-2015 10:39 AM
