turbo oil seals
turbo oil seals
i think my turbo oil seals are on the way out but just wanted to check with you guys.
when i come off boost i get a cloud of blue smoke then it clears is this my seals?.
yes, more than likely. once the engine and esp turbo are up to temp, do you see a puff of blue/whitish smoke when you come off boost/press on the loud pedal. not the end of the world but the stink and non stop rear view mirror checking drive you up the wall eventually. new/rebuilt turbo isnt mega money.
its going to be a long 3hr drive home to moz .
i'v got a spare t3 i'll put on when i get home then i'll get a new or rebuilt one as i dont know how many miles the spare t3 has done.
new/fresh one is sub £600 and gives you peace of mind. tony turbosystems or wilky can rebuild one at a much lower cost and both know there stuff. they can rebuild your t3 to your spec wether it be stage 2, stage 3, ect. the 360 bearing makes a good difference to turbo life.
that was going to be me next question wheres the best place to go,have they got a web site or do i contact them through pf?
tonys a mod off here isnt he?
would runing 15psi and no dump valve cause my seals to go or is it wear and tare?
The chatter/flutter sounds great but i'd rather have a dump valve fitted if its going to save me turbo.
think you will be ok m8 theres others who are running a higher boost and have no probs
turned out to be a blocked breather i just hope i havent done any damage
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
st220kyle
16
14-08-2015 06:13 AM
