PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. heat wrap for plug leads
  2. Cosworth engine that been stood over 18 year
  3. zetec ideling issues.
  4. cheap focus rs wings
  5. sapphire cosworth
  6. Bluefin????
  7. Cosworth worm drive (pic) removal??
  8. Focus brake light problem (stays on)
  9. Mondeo TDDI Fuel Pump Help.
  10. lambda sensor voltage?
  11. zetec turbo head gasket
  12. 2001 mk5 fiesta no spark
  13. 2wd inlet, 4x4 inlet, spacers? Explain?
  14. focus 2.5t st engine in a mondeo
  15. cosworth fuel pump rewire?
  16. Ford Focus 1.8 TDI Engine Cuts Out
  17. Converting all ball joints to rose joints/rod ends!
  18. Idle issue...
  19. boost issues any ideas??
  20. zetec clutch
  21. whats wrong with my cossie???
  22. OFAB temp sensors question...
  23. Trouble with TDCI 130 engine cutting out.
  24. Focus and Mondeo Injectors
  25. 1.8 endura turbo diesel
  26. witch ecu?
  27. p0171 system too lean bank 1
  28. focus st170 conversion, straight swap?
  29. Mk6 escort van owners plz
  30. ABS Diagnostic Plug
  31. oli light on at idle?
  32. Help...!! 4x4 Saph cossie ABS problems...!!!
  33. Engine loom connection
  34. MT75 gear stick replacement needed
  35. engine management question???
  36. bubbles in my cossy header tank
  37. Windscreen Rubber loose is it dangerous?
  38. steering shaking when braking
  39. chatter noise, why is it different on mine?
  40. Head gasket and bolts ... againg ... :-)
  41. will my erst blow ?
  42. do you know???????
  43. 3 Door Help
  44. MOT Fail!
  45. Fiesta rs turbo wiring diagram
  46. over boost erst!!
  47. T reg 1999 Fan heater problems
  48. s2 rs turbo problem please help
  49. saph rear lights going crazy
  50. series 2 clutch .. HELP PLEASE
  51. mk4 xr3i vibrating issues
  52. Escort Cosworth Bias Pedal Box
  53. Engine Management Light
  54. ERST Series 2 turbo failure? Help
  55. Dunno what this bit in my engine is?
  56. what way dose a zetec water pump operate?
  57. No boost, now this is a mess!
  58. fitting an aftermarket(non cossie) ally rad to cossie
  59. ka chassis rails
  60. escort cosworth steering problem
  61. Impact of not changing hot spot fly wheel ..
  62. MAjor Problem round drivers wheel area
  63. best place to get sound deadening
  64. oil for rs turbo
  65. sapphire boot wont open
  66. clunk when letting off accelerator
  67. Electric cooling fans do not turn of on Focus 2.0
  68. running lean
  69. ST170 Clutch replacement
  70. Turbo'ing a 2l zetec
  71. focus tdci starting problem
  72. Rear Beam Mount - chassis leg
  73. ST170
  74. Strange indicator problem with trailer
  75. Focus rs boost problem?
  76. pss9 for a 2wd
  77. gearbox noise help
  78. Ford Radio Problems. Anyone can help?
  79. 2.9 cologne distributor
  80. Fiesta 04 TDCI Wont Start
  81. Rear wheel hub query
  82. list of engines
  83. turbo oil restrictor fitting
  84. sierra v6
  85. Focus/FRS Bush alignment
  86. which clutch do i use?
  87. 03 mondeo TDCI (odd noise)
  88. st170 - quaife atb fitment
  89. 2.0l cabby
  90. can i put xr3i injectors on Treg 1.6 escort
  91. Mind boggling missfire???
  92. 4x4 Coolant hoses
  93. cossie idle problem
  94. fuel pressure needed
  95. escort rst lump into fiest rst
  96. Air conditioning problem
  97. gearbox info?
  98. Fan belt tensioner
  99. 2.0 pinto ignition timing?
  100. Camshaft Specs
  101. Help puma1.7 stalled and not starting
  102. zetec turbo wiring help mk5 fiesta
  103. Escort GTi quickshift
  104. xr4i 2.8 xr4x4 2.8 engine
  105. What Boost??
  106. my car will not go into gear its stuck in 3rd is it gear linage
  107. ST170 Dreamscience HELP..!!
  108. How to turn up the boost?
  109. Radio codes
  110. Over boosting, turbo been changed
  111. mondeo 2.5 v6 zetec s.. fault!!!!!!!
  112. Cosworth 4x4 front driveshafts and CV Joints
  113. Innovate LC-1 Problems
  114. When Machining a 200 Block for Long Studs...HELP!!
  115. knocking from front when steering -Escort
  116. anyone good with electrics
  117. mondeo sci timing chain jumped again
  118. Mental wheel wobble!!! Please help
  119. 97 escort imobiliser light permantly on
  120. Phase sensor.
  121. 2wd Cosworth Fuel lines.
  122. My pinto setup! Comments?
  123. Cosworth misfire
  124. Duratec 2.0 use for Kit Car
  125. rwd zetec into a rwd nova
  126. group a breather
  127. Break disk replacement.
  128. XR3i 8v efi runs like a queer.. (dyno run included)
  129. 53 plate focus cmax 1.8
  130. Building up a 200 block
  131. fiesta mk6 st 300mm calipers on a mk5 zetec
  132. mondeo turbo engine conversion
  133. Mondeo Duratec HE 1.8 puzzle?????
  134. mondeo hanbrake
  135. gearbox starter motor help me please
  136. Help! Very strange noise.
  137. suspension brake hose
  138. cosworth cam belt problem
  139. Auto box woes
  140. what carb?
  141. ZVH Question
  142. Newb needs help please.
  143. suspension problem
  144. Problem with high beam
  145. renault 5 tdc sensor
  146. sierra rear beam bushes?????
  147. white smoke from exhaust
  148. zetec engine conversion help!!!
  149. juddering when pulling away in first.. help plz
  150. Fuel lines (Cosworth)
  151. Losing oil through airbox...?! :(
  152. The Joy of an alternator problem :-)
  153. Dash lights
  154. yb turbo wiring
  155. help need more power (alot more)
  156. head
  157. crank question
  158. 2005 Transit Van Problem
  159. turbo's and carbs
  160. Focus mk1 rs injectors 440cc?
  161. t3 turbo wastegate arm
  162. burning oil
  163. power steering problem on galaxy
  164. '99 Escort 1.6 16v shaking from cold start
  165. power problem escort gti
  166. problem with tracking
  167. CVH excessive breathing and oil loss
  168. help with starting problem please
  169. Fiesta Turbo engine cutting out???
  170. T38 on a standard Cossie
  171. 1999 Ford Focus TDDI Head Bolts Torque Settings
  172. 2wd-4wd cosworth steering coupling conversion
  173. Mk3 escort brake pipes
  174. How to put belt back on after changing alternator
  175. Rs2k head on 2.3 block
  176. wireing issues
  177. Brake line diagram - Cossie 4x4 Master to ABS Distribution Block
  178. Escort S2 Clocks
  179. crank pick up for escort rs turbo engine
  180. relay
  181. 5 door XR4x4 floor pans
  182. Relays
  183. Random fault that's driving me batshit..
  184. Harness Bolts
  185. Pushrod to Zetec help needed asap
  186. muppet needs help please.......
  187. glow light wont come on
  188. Newbie in need of help Brake upgrade
  189. map sensors
  190. Cobra alarm help think immobiliser is stuck
  191. '00 focus front indicators
  192. Where To Get Garrett Gt28 Flange/Downpipe?
  193. xr2 misfire
  194. 3 door Chips
  195. What original tyre size
  196. focus front mount
  197. Immobiliser fault?
  198. Electric hood probs
  199. ERST Brake Problem
  200. mk1 fiesta brakes
  201. MAS?
  202. weber twin 40s
  203. escrt cosworth starting problems ???
  204. Where to find Pectel monitor???
  205. MT75 disassemble/strip down guide
  206. L8 with pectel baby board to 2wd cossy?
  207. white smoke issue
  208. Con Rod bolt question
  209. how can i make a crappy derv fiesta go faster??
  210. diff ratio
  211. BOA Warm start issue
  212. xr3i gearbox trouble
  213. Oscillating AFR
  214. st220 losing oil, smoke through exhaust
  215. AFR Narrowband measurement
  216. Ideal N/A fuel ratio's
  217. what ecu is in a rst
  218. MT75 3rd Gear gone! Help!!
  219. XR4i Stalling and not starting
  220. Focus TDCi running problems.
  221. 93' fiesta xr2i 16v.... Any 1 got a pinout guide for ecu wires????
  222. gearbox rating
  223. 99 Escort 1.8D Van Help
  224. silver or black top zetec turbo engine?
  225. cosworth focus 2wd quick help
  226. Escort rs not happy!! Help!!
  227. Fiesta mk6 hubs are they all the same
  228. help xr3 van wireing
  229. focus cd player fault
  230. sapphire 2wd cossie advise please!!!
  231. oil filter housing
  232. Low idle & stalling focus (& related air con prob?)
  233. 99 foicus front slam panel
  234. zetec manifold
  235. water pump
  236. reyland hydraulic clutch kit
  237. twin engined fiesta
  238. Saffcos rear bumper change
  239. ERST Oil Type?
  240. ERST -31 Collins Actuator
  241. mappers / tunner in lincoln/ A46
  242. abs on 2wd sierra cos
  243. wiring a fuel pump realy?
  244. electrical fault focus tdi
  245. GRRRR advice please
  246. turbo damper removal
  247. WARNING Lights on Sierra Cos 4x4
  248. efi conversion flywheel fitted ???
  249. cosworth saver shim
  250. rs turbo, where to get recon turbo
