View Full Version : Technical help Q & A
- Anybody familiar with assembling the MTX75
- Fuel pump help
- a quick sierra cosworth id question
- Where can i find a replica ford focus mk1 wrc full decal kit 2000
- cosworth coil rewire
- cosworth engine strip and rebuild
- coilover rebuild help
- Can it be got ?
- Zetec Lowered Compression Help
- focus miss fire... coil pack?
- Installing Sub and amp.
- Escort series 2 lsd
- blue smoke !!!
- seats and seatbelts
- not starting with key after a d-td conversion
- zetec se
- Does anyone know were i can get.....
- ARP conrod bolts
- Welding...
- Cosworth fuel line ends
- 74c thermostat on rst
- 83lb seimens black injectors part number?
- at what revs will my turbo kick in roughly?
- 4x4 CTS location and Fault codes
- escort s2 fuel actuator
- rs2000 recaros
- Saph cos fog lights
- cvh 1640 tuned = 64 bhp? help please
- 4WD Cooling
- Bodywork and Restoration Help!!
- New RS Turbo Owner - 1.6 CVH In XR3i - Some help req please!
- ST 170 clicking steering?
- Escort G3 code 10 error code
- pinto injection wont idle
- Are there any quality aftermarket pumps for Foc RS mk1?
- Smokey Mondeo
- Mondeo start motor removel
- Clutch pedal
- 1998 Focus 2.0 Ghia - Timing Belt failure ??
- focus traction control retrofit/kit
- fitting new new wheel studs.
- Fog light bolts fooked
- Problems fitting 2wd Saph poly diff mount?!
- Code missing
- Those little bulbs
- Power steerin pump/ pulley cosworth 4wd
- help needed engine stuttering/jerking when accelerating
- ford sierra computer
- Which turbine housing is better for my 2.0 turbo
- MK4 escort zetec question
- Knackered Mk6 Gearbox?
- missing
- Help needed for Zvh CR....?
- what car would they fit
- escort mk3 door hinge pins
- Mk4 XR3I EFI Cabriolet Rear Barke Cylinders?
- 2007 Galaxy 1.8 TDCi
- Courier 2.5 Turbo Diesel smokes
- Escort cos leather
- Cosworth brakes
- 3 door engine loom into a saff, quick question
- Focus 1.8tdci, non start
- rear discs on van
- what conrods for 500hp sierra cosworth engine
- changing spark plugs
- not starting
- juddering in 2nd
- warning light display problem
- Cosworth oil pressure ?
- help on zetec timing
- Shrader/shreader valve on ford mondeo 2003
- need help with my car
- Cosworth Throttle Cable Adjustment ?
- Cossy headgasket best place to get one
- 2 liter z tec,xr31,rs turbo lumps
- s2 escort not running right help!!!!!
- Mondeo 2003 2.0 TDCI fuel problem,
- Non working Air Con on Focus Diesel
- Silver top Compression
- Focus 2002 1.6 Starts up as if choke not on?!?
- how to get rid of sputtering and popping at 4000rpm
- how do you remove cossie fuel feed line?
- GAZ Coilovers
- 1.8 CVH turbo conversion
- noisy escort tdi?
- Ford Escort Mk 6 18 Diesel Engine
- coverting wings to bolt.
- Focus Air Con Issue
- Oil pickup pipe for zetec conversion
- New Front Pads on a '92 RS2000 ,,GREASE ? ?
- Please help with Pectel T3!
- saff 4x4 std turbo
- Help required with part number
- air condition 1.6 cvh!
- x reg focus passanger airbag?
- please help!
- Anyone knows what this means?
- after market steering wheel
- help on brakes
- EGR Valve location Focus MK2 1.8TDCI
- Cylinder Head Temperature Sensor
- Help please.
- cosworth crank pulley
- cdf drop links
- 6 degree beam info
- How to tell if turbo is fitted with Mar-am shaft?
- mike w
- can i run this by someone in the know, engone + 'box combo
- which caliper is this :S
- Need new spark plugs.
- sapphire cosworth race seats
- Cosworth wheels / longer bolts?
- Focus 2.0 Lambda Sensor connector won't line up.
- Mondeo tdci 2002 - Starting Problem
- mondeo tdci 52 plate starting problem
- focus door lock +starting
- bit of help pleasee?
- Securing Perspex windows in doors
- info on rebuild
- Zetec turbo management help needed!!!
- Thread Size - Adaptor under Cossie Inlet ?
- mr james blake
- rs turbo on cos mag engine cuts out
- mondeo tdci fuel metering valve
- 2wd clutch question
- 2wd gearbox oil
- zetec ecu and loom......
- sapphire cosworth flat spot
- knock sensor
- Obsolete relay
- Focus speedo cluster clocks dead ?
- 2.0 cams on a 1.8???
- 1.8 Zetec tuning
- Help needed! Timing Belt Gone
- pectel t6 ecu
- pectel t6 ecu
- mk2 xenon lights
- FRST OFAB loom to zetec xr2i?
- Mondeo Zetec 2.0L Y-Reg - Clutch Advice
- help needed
- Focus MK1 1.6 16V 'whining' noise
- Putting standard suspension back on a sierra
- zetec wiring
- Spark Plugs
- Car felt sluggish last night
- engine bay decals
- mfi wiring !
- mondeo tdci 130 2002
- MFI wiring diagram
- Difference between heads
- Duratec question...oil filter/oil cooler
- help me please !!!!!!big problem
- Inlet manifold spacer
- knocking noise and lose of drive
- Timing Belt/Oil Seal
- How to diagnose a worn steering rack?
- dash lights not working can you help?
- cosworth t34
- zetec conversion
- 4x4 front shafts
- xr2 bolt on wings
- Focus MK1 1.8 - 2.0 Conversion
- Escort Cosworth Airbox
- ZVH compression???
- fwd cossie focus
- new engine a rattler already time to whip it out
- any one no of any good engine rebuilders in devon
- St 170
- St 170
- Is a RED PF09 TPS the same as a BLACK PF09?
- Pinto problem
- RS 2000 throttle bodies...
- Exhaust system?
- focus st no compression ....:-(
- Ford Focus MK1 ECU Remappable? (1.8 2000)
- 2002 mondeo tdci 130
- Wideband
- ecu help........
- Engine Systems Fault - Limp Mode (
- what petrol cap for will fit this ???
- rs turbo rattling problems oil pressure?
- confusing cosworth
- Zetec Engine Identification, mixed 2.0 and 1.8????
- Focus Rs thermostat housing for silvertop turbo water feed
- moniters witch ones the best (value)?
- building a pinto but need help, questions to follow
- MK4 Escort 2.0 Zetec conversion - What parts do I need to make the Mondeo motor run?
- mk5 throttle cable
- Mk4 escort rs 2000 i4 engine conversion Help
- escort cosworth 0.5 boost
- hand brake problem xr4x4 help needed mot due
- 1.8 zvh turbo
- Recommendations for cam re-profiling.
- p100
- Water Temp Housing......
- droning noise from front?
- New Focus Titanium TDCI Stop Start.
- Ford Focus 1.8 Zetec With 218,000
- what fuel hose size cosworth 4x4
- back firing loss of power
- Cosworth thermostat housing problem HELP!
- OFAC v OFAB
- need help urgently
- Mondeo Mk2 Radio help...
- no temperature reading on dash or pod gauge! help
- St2 gearbox price ?
- cam timing help?
- Cosworth ignition amplifier
- efi wiring help
- Fuse help!!!
- Ford radio/CD player
- First Real Problem With my ST170, ALARM
- Bigger brakes under ERST alloys?
- Quick Question
- Side Lighs not working
- amal valve connectors?
- Opinions...large single TB V's ITB's
- xr4x4 handbrake probs help needed
- St3 wire were do they go arrr
- Suitable sierra speedometer ?
- Will focus Rs big end bearings fit zetec e con rods
- mk3 escort to silver top advice
- St170 injectors
- Focus Rough Idle 1.8 MK1
- Abs not workin
- No oil knocking
- 2002 Ford Focus - Heater Blower/Air Con problem
- tuning up
- Heater Blower working on all speeds but not much air throughput
- ignition problem (weber alpha)
- Focus motor / regulator
- COSWORTH PLENUM SPACER 14MM should i ??
- escort mk6 1.4cvh to i4 rs2000
- Focus ST170 emissions.
- Torque value for 12.9 head bolts and gr.A head gasket
- Picture Request - Focus mk1 1.8 engine pics.
- 3bar
- help choosing boost pipe size
- Mondeo TDCI 2002 cut out problem?
- Steering wheel re-trim
- St170
- s2 door skins
- Starter motors and fit?
- Xr3i gear linkage....
- cvh oil pump
- cosworth master cylinder
- Input shaft bearing on T5
- Carbon Wrapping Advice.
- black soot on start up from exhaust.saph cozz
- Cossy wont start
